2D trilateration with three reference points and known distances
  • Context: Graduate
  • Thread starter Thread starter Jose F Gomez D
    2d Triangulation
9 replies · 19K views
Jose F Gomez D
I am trying to code Trilateration but I am not familiar with the math behind it. even though there is an explanation on Wikipedia in this link https://en.wikipedia.org/wiki/Trilateration
and a almost better explanation in here https://stackoverflow.com/questions/9747227/2d-trilateration?answertab=active#tab-top I am still confused on how to do it
I have P1, P2 and P3 as my reference points, and X as the point to find
and I want the distance from P1 to X = 8, P2 to X = 10 and P3 to X = 11
P1 (10,10)
P2 (24,24)
P3 (23,19)
so I have to calculate the unit vector in the direction from P1 to P2, following the formula ex = (P2 - P1) / ‖P2 - P1‖ meaning
ex,x = (P2x - P1x) / sqrt((P2x - P1x)^2 + (P2y - P1y)^2)
ex,y = (P2y - P1y) / sqrt((P2x - P1x)^2 + (P2y - P1y)^2)
ex,x = (24 - 10) / sqrt((24 - 10)^2 + (24 - 10)^2) = 14/sqrt(14^2+14^2) = 14/sqrt(392) = 14/20 = 0.7
ex,y = (24 - 10) / sqrt((24 - 10)^2 + (24 - 10)^2) = 14/sqrt(14^2+14^2) = 14/sqrt(392) = 14/20 = 0.7
then calculating the signed magnitude of the x component of the vector from P1 to P3 by i = ex(P3 - P1)
ix = 0.7*(23-10) = 0.7*13 = 9.1
iy = 0.7*(19-10) = 0.7*9 = 6.3
now calculating the the unit vector in the y direction from the formula
ey = (P3 - P1 - i*ex) / ‖P3 - P1 - i*ex‖**but here how do I continue?**I am assuming to continue like this
ey,y = (P3y - P1y - iy*ex,y) / sqrt((P3x - P1x - ix*ex,x)^2+(P3y - P1y - iy*ex,y)^2)
ey,x = (P3x - P1x - ix*ex,x) / sqrt((P3x - P1x - ix*ex,x)^2+(P3y - P1y - iy*ex,y)^2)
ey,y = (19 - 10 - 6.3*0.7) / sqrt((23 - 10 - 9.1*0.7)^2+(19 - 10 - 6.3*0.7)^2)
ey,x = (23 - 10 - 9.1*0.7) / sqrt((23 - 10 - 9.1*0.7)^2+(19 - 10 - 6.3*0.7)^2)
ey,y = 0.6
ey,x = 0.8
then the distance between the centers P1 and P2 is ‖P2 - P1‖
d = ‖P2 - P1‖ = sqrt((P2x - P1x)^2 + (P2y - P1y)^2) = 20
then the signed magnitude of the y component from j = ey(P3 - P1)
jxx = 0.6*(23-10) = 0.6*13 = 7.8
jxy = 0.8*(23-10) = 0.8*13 = 10.4jyx = 0.6*(19-10) = 0.6*9 = 5.4
jyy = 0.8*(19-10) = 0.8*9 = 7.2
then finally from https://stackoverflow.com/questions/9747227/2d-trilateration?answertab=active#tab-top
x = (r12 - r22 + d2) / 2d
y = (r12 - r32 + i2 + j2) / 2j - ix / jx = (8^2 - 10^2 + d^2) / 2*d = (8^2 - 10^2 + 20^2) / (2*20) = 9.1
y = (8^2 - 11^2 + i^2 + j^2) / (2*j - (ix / j))
**What do I do?**
please help
Mathematics news on Phys.org
I have no idea what this method involves. However there is a straightforward approach as follows, with X=(x,y)
[itex]1)\ (x-10)^2+(y-10)^2=64[/itex] (distance to P1 squared)
[itex]2)\ (x-24)^2+(y-24)^2=100[/itex] (distance to P2 squared)
[itex]3)\ (x-23)^2+(y-19)^2=121[/itex] (distance to P3 squared)
Combine equations: 1) minus 3) to get 4), 2) minus 3) to get 5). 4) and 5) are linear in x and y. Solve and check to see if they satisfy 1), 2), and 3).
nop it does not work in this way
P1 = x^2-20x+100+y^2-20y+100=64
P1 = x^2-20x+y^2-20y=-136P2 = x^2-48x+576+y^2-48y+576=100
P2 = x^2-48x+y^2-48y=-1052P3 = x^2-46x+529+y^2-38y+361=121
P3 = x^2-46x+y^2-38y=-769P4=P1-P3(x^2-20x+y^2-20y=-136)-( x^2-46x+y^2-38y=-769)
(x^2-20x+y^2-20y)-( x^2-46x+y^2-38y)=633
P4 = (26x+18y)=633P5=P2-P3(x^2-48x+y^2-48y=-1052)-( x^2-46x+y^2-38y=-769)
(x^2-48x+y^2-48y)-( x^2-46x+y^2-38y)=-283
(-2x-10y)=-283
P5 = (2x+10y)=283Substitution
(26x+18y)=633 y=(633-26x)/18
(2x+10y)=283 (2x+10((633-26x)/18))=283
(2x+((6330-260x)/18))=283 36x+6330-260x=283*18
6330-224x=5094 1236=224x
x= 5.52
y=(633-26(5.52))/18= 27.2
replacing x and y on P1,2,3
〖5.52〗^2-20*5.52+〖27.2〗^2-20*27.2=315.91
wrong
〖5.52〗^2-48*5.52+〖27.2〗^2-48*27.2=351.75
wrong
〖5.52〗^2-46*5.52+〖27.2〗^2-38*27.2=372.79
wrong
That is a really strange way of writing it.
The approach is right, if your result is wrong you did a mistake somewhere in between.
No, the calculation is right, x and y works with p4 and p5 but not with p1,2,3, it will never work I have checked online, this does not count, at the end I need trilateration not this
I checked the equations, your initial equations don't have a solution to start with.
Here are p1 and p2. The problem is easy to track down:
P1 (10,10)
P2 (24,24)
P1 and P2 have a distance of 14*sqrt(2) > 18. There is no such point.
OMG, I do not have ecuations, I have coordinates in an x y Cartesian map, p1 is located in 10,10
Yes, and P2 is located at (24,24), that is 19.8 away from P1. There is no point that is 8 away from P1 and 10 away from P2, that would violate the triangle inequality.
Using graph paper and a compass, one can easily see if there is a solution. Place each point on the paper and use it a center of a circle with radius equal to the distance to the unknown point. If the three circles have a common point of intersection that is the solution. Otherwise (as in this case) there is none.
