What is the configuration of 3 blocks connected by a line and its balance?
  • Thread starter Thread starter mojki1
    Blocks Line
The discussion focuses on determining the balance of a system of three blocks connected by a line, with a friction coefficient (µ) and an angle (α) of 30 degrees. The key equation derived is mgsin(30°) + µmgcos(30°) + µmg = 2mg, which describes the forces acting on the blocks. Participants clarify that the blocks are stationary, and the task is to find the limits of the masses for which the system remains in balance, rather than limits for µ. The final consensus emphasizes the need to approach the problem from the perspective of mass ratios rather than friction coefficients.
  • Understanding of static equilibrium in physics
  • Knowledge of forces acting on inclined planes
  • Familiarity with friction coefficients and their implications
  • Ability to manipulate and solve algebraic equations
  • Study the principles of static equilibrium in physics
  • Learn about forces on inclined planes and their calculations
  • Explore the role of friction coefficients in mechanical systems
  • Practice solving problems involving multiple connected masses
Students studying physics, particularly those focusing on mechanics and static equilibrium, as well as educators seeking to clarify concepts related to forces and friction in multi-body systems.
mojki1
Last time I have had problem with one task:
http://img543.imageshack.us/i/cosc.jpg/
They questioned us to determine compartments in with that configuration will be on balance.
Informations:
u-Friction
alpha=30
If that configuration must be on balance so acceleration must be 0. So we can compare forces working on that blocks.
-Qx1-T1-T2=Q3
If we compare forces which working on that configuration we will go to moment that masses of that blocks will be reduced.
-mgsin(30)- umgcos(30)-umg=2mg
But this is not a solution of that task.
Sorry for my language. Thx for help:smile:
hi mojki1! :smile:
(have an alpha: α and a mu: µ and a degree: ° :wink:)
what exactly is the question?
are the blocks stationary, or are they moving with zero acceleration?
i'm guessing that you mean that the blocks are stationary, and that the question wants you to give the limits (not "compartments" … that doesn't mean anything in physics :wink:) (on µ) within which that is possible
if so, your answer should have "µ" on one side on its own (and perhaps should have a ≤ or ≥ rather than an =) :wink:
-Qx1-T1-T2=Q3
your final equation looks correct to me (except that the minuses should be pluses, and you need to cancel the mgs and make it an equation for µ)
btw, "If we compare forces which working on that configuration we will go to moment that masses of that blocks will be reduced" …
i think you mean something like "If we equate the forces on that configuration (or system) at the instant that the blocks are about to move" :smile:
You 're right tiny-tim. The blocks are stationary and question is about the limit of the masses of that blocks for which the system remains in balance. µ is given.
Final equation should looks:
mgsin(30°)+ µmgcos(30°)+µmg=2mg
But this isn't standard task that we have to designate limits for µ, we need designate limits for masses not for µ. µ is given. If i compare that equation, masses will be reduced, so i think that we have to look for this problem from another perspective
hi mojki1! :smile:
if µ is fixed (what is it, btw?), and if the ratio of the masses (m:m:2m) is also fixed, then the value of m makes no difference :confused:
there must be something missing from the question :redface:
µ is constant for all blocks, only masses are your variables
EDIT:
data for this task were symbols
13K
