What machines are used to manufacture extruder screws for 3D printers?
The discussion centers on the manufacturing processes and machines used to create extruder screws specifically for 3D printers. Participants explore various methods, tools, and design considerations relevant to this topic, including the challenges of producing screws with specific dimensions and profiles.
  • Homework-related
  • One participant expresses confusion about the types of machines used to manufacture extruder screws for 3D printers.
  • Another participant suggests that milling tools might be used due to the specific design of extruder screws, which have threads that are farther apart.
  • Some participants mention the complexity of extruder screws, noting that they typically have multiple sections with different dimensions, making them challenging to manufacture.
  • A suggestion is made to use an axial NC grinder or a modified 4-axis engraver for manufacturing these screws.
  • There is a discussion about the possibility of using an angle grinder or tool post grinder for simpler designs of screws.
  • Participants inquire about the specific dimensions and details of the screws needed for the project.
  • One participant mentions the need for benchmarking to understand existing manufacturing processes before designing a new machine tool.
  • Several participants encourage the use of online resources and videos to learn about different machining methods relevant to screw manufacturing.
Participants do not reach a consensus on the specific machines or methods used, as multiple approaches and tools are suggested. The discussion remains open-ended with various viewpoints on how to manufacture extruder screws.
Participants express uncertainty about the exact manufacturing processes and tools used by manufacturers, indicating a need for further research and exploration of existing methods.
This discussion may be useful for students, hobbyists, or professionals interested in 3D printing technology, specifically those looking to understand the manufacturing of extruder screws and the associated machinery.
Tung Jian Seng
Currently I am working on an assignment about making an extruder screw for screw based 3D printer. I am confused that actually what kind of machines those manufactures out there using to manufacture this kind of extruder screws ?
Welcome to PhysicsForums. :smile:
A Google Images search on extruder screw design gives lots of good hits. Here is one:
Thanks a lot ! But I have a doubt... wondering how actually this kind of screw is made by those manufacturers and what kind of machines they using.
How are regular steel screws made? I suppose since the threads on the extruders are farther apart with flat surfaces between them (the shaft body), you would use a milling tool that moves along removing material down the length of the shaft. Have you tried using Google or Google Images with good search terms to find examples of various screw manufacturing processes? Google-fu is an important skill to develop... :smile:
Yesss I have searched on the Google. But I can only find those big plastic extruder screw manufacturing process. So I am curious about how are small sizes extruder screws for 3D printer are made by those manufacturers :)
Welcome, Tung!
Do you have to make the screws or also to design them?
Can’t you find spare parts if for existing printer?
Can't you just machine them?
An extruder screw usually has three separate sections, each with a different OD, ID, pitch and profile. That makes it difficult for the average workshop.
I would use an axial NC grinder.
A modified 4-axis engraver could do the job if the head was replaced with a 90° degree head and a cutting disk.
What are the dimensions and details of the screw you require?
Lnewqban said:
Welcome, Tung!
Hi, Lnewqban !
I need to design a modular machine tool that can be added on a lathe machine and make extruder screws for 3D printer.
I need to design a machine tool that can be added on a lathe where it can be used on making extruder screws for 3D printer. I am planning to use an angle grinder. But before that I need to survey how those manufacturers actually making this screw. The survey is for benchmarking purpose.
It is a project I need to design a machine tool that can be added on a lathe where it can be used on making extruder screw for 3D printer. But before that I need to do benchmarking. So I want to know what kind of machines that manufacturers out there actually using on making this kind of extruder screws.
Your screw is simple with only one ground flute. A tool post grinder will do that job. You might use an angle grinder as a crude tool post grinder.
You will need to modify the lathe. The lead screw on a lathe is probably finer than the screw you are grinding. Because the pitch of the extruder screw is longer, you will need to drive the lathe lead-screw very slowly with a motor and reduction gearbox. The chuck holding the extruder screw is then driven from the lead screw through a reduction ratio that sets the pitch of the thread you are grinding.
BTW, is this project for schoolwork?
Yupp it is a schoolwork.
Okay, thanks. I'll move the thread to the schoolwork forums for you now.
Thank you very much !
