3I/ATLAS, Interstellar Comet
  • Level: High School
  • Thread starter Thread starter Astronuc
22 replies · 11K views · last reply
Staff Emeritus
2025 Award
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025.
Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread.
https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/
One source mentions the comet traveling at 68 km/sec, or 244.8 km/hr! The Wikipedia article indicates speed at perihelion of 68.3 km/sec.
https://en.wikipedia.org/wiki/3I/ATLAS
the newly discovered object was entering the inner Solar System at a speed of 61 km/s (140,000 mph; 220,000 km/h) relative to the Sun, located 3.50 AU (524 million km; 325 million mi) from Earth and 4.51 AU from the Sun, and was moving in the sky along the border of the constellations Serpens Cauda and Sagittarius, near the galactic plane.
https://en.wikipedia.org/wiki/3I/ATLAS#Discovery
It will pass between the orbits of earth and Mars, with the Comet's trajectory projection on the ecliptic intersection the orbit of Mars twice.
https://science.nasa.gov/solar-system/comets/3i-atlas/
Comet 3I/ATLAS poses no threat to Earth and will remain far away. The closest it will approach our planet is about 1.8 astronomical units (about 170 million miles, or 270 million kilometers). 3I/ATLAS will reach its closest point to the Sun around Oct. 30, 2025, at a distance of about 1.4 au (130 million miles, or 210 million kilometers) — just inside the orbit of Mars.
Astronomy news on Phys.org
I also ran across the discussion in the new persons thread.
It got me interested in how long it would take the comet to travel interstellar distances at its approximate speed. Here are 4.
3I-Atlas
(v∞ = 58 km/sec)
Proxima Centauri
(nearest star)
Ross 154
(nearby in the direction of Sag A*)
average distance of nearest 100 stars
Sagittarius A*
(black hole at the center of our galaxy)
distance
(ly)
4.25
9.7
time to travel
(years)
22,00050,00088,000140,000,000
{2025.08.14 20:08 PDT: edited to fix speed booger, per Filip Larsen
Odd that I made the mistake as I had noticed the v∞ speed in the wiki article.
Chalk this up to 'Senility Now!' :biggrin:}
It looks like you used the perihelio speed at 68 km/s and not the hyperbolic excess speed (i.e. the speed far from the Sun) estimated at 58 km/s, so the time to travel should probably be around 17% larger.
Fixed!
I think I may have originally used 58 km/s in my calculations, but I kept adding distances, and by the time I'd finished, I went back and double checked Astro's post to see if I was repeating something he said, which I think is where I saw 68, and decided that I'd made a typographical error, and in error, I unfixed it. :headbang:
In any event, thank you.
OmCheeto said:
Fixed!
And points for rounding the numbers to significant figures!
I assume the idea for the table is to get a grasp for what a speed of that magnitude means for travel time and thus on purpose ignores where 3I/ATLAS is actually heading. But just in case anyone now wonders if the comet will reach the center of our galaxy in around 140 million years, then the answer is no since 3I/ATLAS, just like the solar system, is in an orbit around the galactic center. However I have so far not read (or had time to try calculate it myself) to what extend this encounter between the two has significantly changed the galactic orbit of the comet, but from the small deflection angle I would suspect it has not.
Thanks!
The original format, while 'significant figures' ugly, was done on purpose, as along with my brain, my eyes are going bad, and the commas looked like decimal points, and made it quite confusing to look at. Obviously that was before I had added Sag A*.
After I fixed the numerical error, I decided that 'Sag A*'s travel time negated the whole 'old people like me might get confused' argument. And then some weird sense of 'transcription error' paranoia was overcome and I followed my hero's lead and dropped everything down to 1 or 2 decimal points.
I guess you could call it 'conversational significant digits', which is obviously not the same as that of the scientific sense.
The table was inspired by two things:
1. Brian Cox's most hilarious comment in human history. I was curious how long ago, some "sentient molecular cloud", had propelled a "giant space turd" at us.
2. The comet is coming at us from the direction of the galactic center.
Given that I had no clue what stars are in the galactic center direction, I started with our nearest neighbor. After quite a bit of googling, I discovered Ross 154.
I then went and found an old list of our 100 nearest neighbors and was quite surprised how close they were.
In the end, I decided that 3i/Atlas could have come from near the galactic center.
But this prompted a couple of new questions:
1. How many stars did 3i/Atlas significantly interact with if this were true?
2. If it were 'A LOT', then it seems like it would have run out of gas by now, indicating this was a nearby star supplied comet. Which begs the question; "Will we one day be able to determine the approximate distance these interstellar comets travel from an analysis of their outgassing?"
I had a similar question about how far Oumuamua had traveled. But as often is the case, didn't know how to phrase the question without sounding like an idiot.
This is only relative to us in the solar system. Relative to our galaxy the comet is in an orbit similar to that of the solar system where it (in lack of other close encounters) has been and will get a bit closer to the galactic center, but not significantly so. The orbit can be seen at https://en.wikipedia.org/wiki/3I/ATLAS#Origin_and_age, but as mentioned one should take the multiple "round-trips" depicted to only be an indication of the orbit before or after the current passage, and not as an accurate prediction of there the comet has been or will be for billions of years. It could be interesting to know with what precision (in time and space) the actual in- and out-bound trajectory can be calculated relative to the stars in the local arm of the galaxy. Considering the great distance between stars I suspect it might be possible to give the orbit a sort of statistical measure under the assumption that close star passages for one specific interstellar comet really is rare.
Edit: a larger image of the same orbital view from the team behind is included below. I was not able to find the exact orbital elements used, if such data even makes sense for galactic orbits.
https://ras.ac.uk/news-and-press/re...-interstellar-object-may-be-oldest-comet-ever
https://ras.ac.uk/sites/default/files/2025-07/Fig3-map_faceZoom-unlabelled.png
i'm wondering whether it's possible to send a probe to intercept or even hitch a ride with such interstellar objects, that way human can map space outside our solar system much faster than current probe does (voyager 1 &2).
It's been discussed.
There are a number of technical challenges including
- spotting an incoming body early enough to get a payload in front of it (especially since we don't know anything about location, speed and trajectory until we actually discover one), and
- having a probe ready-to-go
- being powerful enough to make the delta-v change necessary to intercept it at less than vapourization speeds - 3I/Atlas is moving at 3-4 times the speed of the Voyagers.
We have two craft that are faster - much faster - but both are sun divers, so not useful for targeting an object passing through our outer system.
I recently found a simulator and it looks as though 3i's trajectory after it leaves our solar system is directly in line with Sgr A*.
Well, to me it appears that is heading the opposite direction.
But not that this matters much because no matter what direction relative to the Sun it leaves in it will be in a similar galactic orbit as the Sun because it is "only" leaving with around 58 km/s relative to the Sun, which in turn is doing 230 km/s in its galactic orbit. For an interstellar comet to go from the Sun to the galactic center it would have to leave the Sun at around 230 km/s (no more, no less) in retrograde direction in order to make a near radial trajectory towards galactic center.
See also https://lweb.cfa.harvard.edu/~loeb/SL_25.pdf where the authors have done some numerical trajectory work (back in time) on 3I/Atlas and the two preceding objects, 1I/‘Oumuamua and 2I/Borisov. Fig. 7, 8 and 9 show details on the 3I/Atlas trajectory. In Fig. 8 you can see that the closest it has been to galactic center is around 7 kpc relative to the mean Sun distance at 9 kpc (the red X on the left is galactic center). From this figure it is also clear that 3I/Atlas is in a more eccentric orbit than the Sun, but not overly so.
Depends on your FoR. You are choosing a FoR based on the fixed background of stars.
But you don't have to. We can discount the concentric velocity and only look at the radial velocity.
Like when we examine the trajectory of a Mars probe. Sure, it has a lot of concentric motion (relative to the fixed background of stars), (yellow) but it's still headed (mostly) directly to the Mars from our FoR on Earth (orange) and that is, ultimately, where it will end up.
(The diagram would work as a better analogy if it depicted a sun-diving probe.)
When I said; "...leaves our solar system is directly in line with...", I did not mean 'towards'.
Other than that minor vector foible, I think we're on the same page.
I would love to be able to comprehend even a minor bit of galactic orbital mechanics, but I'm afraid my brain is in very serious decline, and won't be able to keep up with such things.
ps. Love that you referenced the Abi Loeb paper. Guessing he's the new Max Tegmark. It took me a few weeks to figure out what Max was up to back then, but then it clicked.
I was referring to the simulator page that OmCheeto gave in #10, on which the outbound trajectory of I/Atlas is shown to point directly away from galactic center. I then took OmCheeto's comment that "3i's trajectory after it leaves our solar system is directly in line with Sgr A" as a statement that it was leaving towards galactic center.
The rest of my post I just talked about the fun weirdness of orbital mechanics (and not really about FoR) so I am not sure if and how your reply relates to that part or if you just meant the first line of my post (you quoted both, so I am confused). As I read your post we are not really disagreeing on anything.
I am as such not familiar with the work of either of them, but guess you perhaps are refering to Loeb's (recent?) list of pop-sci appearances? Papers on arXiv with Loeb on the author list totals to 783 so he seems quite active in "actual science" too.
Since I don't know Tegmark its not really surprising that I have no clue what you refering to here. :wink:
It was decades ago, so don't quote me on this. I recall that he posted some Loebesque 'out there' type papers, which attracted a lot of peoples attention. He mentions this on his web page:
"Every time I've written ten mainstream papers, I allow myself to indulge in writing one wacky one, like my Scientific American article about parallel universes." [ref]​
I seem to recall these wacky ones were usually published around April fools day. But as I mentioned above, don't quote me on any of this.
According to wiki, he has a Ph.D and teaches at MIT.
They list his fields as: Cosmology, physics, and machine learning
pinball1970 said:
https://arxiv.org/abs/2510.25035 Brightening as it approaches the Sun.
"resolves the comet as an extended source with an apparent coma ~4' in diameter."
How can they even see it if it's no bigger than a dishwasher??
:wink:
  • Haha
DaveC426913 said:
Ya think? :oldbiggrin:
Oops, I missed the winky face in your post. NVM...
https://arstechnica.com/science/202...-know-that-3i-atlas-is-an-interstellar-comet/
Since early July, telescopes around the world have been tracking just our third confirmed interstellar visitor, the comet 3I/ATLAS—3I, for third interstellar, and ATLAS (Asteroid Terrestrial-impact Last Alert System) for the telescope network that first spotted it. But the object’s closest approach to the Sun came in late October during the US government shutdown. So, while enough people went to work to ensure that the hardware continued to do its job, nobody was available at NASA to make the images available to the public or discuss their implications.
So today, NASA held a press conference to discuss everything that we now know about 3I/ATLAS, and how NASA’s hardware contributed to that knowledge.
