What Is the Correct Interpretation of 4-Vector Momentum Squared?
  • Thread starter Thread starter Ene Dene
    4-vector
The correct interpretation of 4-vector momentum squared is given by the equation P^2 = P_{\mu}P^{\mu} = m^2, where P represents the 4-momentum vector. In this context, E is the total energy of the particle, and the relationship E^2 = p^2 + m^2 holds true when using natural units (c=1). The common misconception that E = mc^2 applies universally is incorrect; it only holds in the rest frame of the particle. The relativistic momentum is defined as p = \gamma mv, where γ is the Lorentz factor.
  • Understanding of 4-vectors in special relativity
  • Familiarity with the Lorentz factor (γ)
  • Knowledge of relativistic energy-momentum relations
  • Basic concepts of momentum in physics
  • Study the derivation of the energy-momentum relation in special relativity
  • Learn about the Lorentz transformation and its implications for relativistic physics
  • Explore the concept of relativistic mass and its distinction from rest mass
  • Investigate the applications of 4-vectors in advanced physics problems
Students and professionals in physics, particularly those studying special relativity, theoretical physicists, and anyone interested in the mathematical foundations of momentum and energy in relativistic contexts.
Ene Dene
I'm having a problem understanding this:
P^2=P_{\mu}P^\mu=m^2
If we take c=1.
Here is what bothers me:
P(E, \vec{p})=E^2-(\vec{p})^2
Now, I assume that E=mc^2, and for c=1, E^2=m^2? Is that correct?
And I don't know what p^2 is, I look at it as:
(\vec{p})^2=m^2(\vec{v})^2
What am I doing wrong?
If we take c=1.
I am not exactly sure what bothers you but one point: E = \gamma m c^2, not mc^2 (which is valid only in the rest frame of the particle). Also the momentum is the relativistic three-momentum so it's \gamma m \vec{v}
Your first equation shows m^2=E^2-p^2.
Your assumption E=m is wrong.
If we take c=1.
Now, I assume that E=mc^2, and for c=1, E^2=m^2? Is that correct?[/tex]
The symbol 'E' in this equation is the total energy of the particle. The popularly-known equation E = mc^2 refers to the "rest mass-energy of the particle" and is really an incorrect use of the symbol.
'p' here is just the regular ol' 3-momentum, mass times the 3-dimensional velocity vector for the particle. The so-called "4-momentum" P^{\mu} is a 4-dimensional vector whose components are
( iE, p_x, p_y, p_z ) [or flip signs depending on whose notational convention you use].
Your original relation then,
P^2=P_{\mu}P^{\mu}
is then just taking the "dot product" of P with itself to get the square of the magnitude,
P^2 = E^2 - p^2 = (mc^2)^2 , again with appropriate adjustments for local notational practice.
As already said, the popular formula E = mc^2 -- mostly misquoted -- is a) not generally applicable and b) not even a main result of special relativity, it's more like a small remark buried somewhere deep inside the text.
To stick with Ene Dene's approach: if you plug in the correct formula
E = \sqrt{ (\gamma m c^2)^2 + (m p^2)^2 }
you will get a consistent result.
In units where c = 1, it'd be
E^2 = \gamma m^2 + p^4
and
p = \gamma m v.
Also note that you can deduce where E = mc^2 is applicable; the general formula reduces to it in the rest frame (p = 0) at non-relativistic speeds (\gamma \approx 1).
  • · Replies 32 ·
