6 Successive numbers no one is prime
  • Context: MHB
  • Thread starter Thread starter Amer
    Numbers Prime
The discussion revolves around the possibility of finding six consecutive integers such that none of them is prime. Participants explore various examples and generalizations related to this problem, including specific values and methods for generating such sequences.
  • Some participants propose that setting \( x = 5! \) yields a valid solution where none of the six consecutive numbers is prime.
  • Others suggest that \( x = 90 \) provides a longer sequence of consecutive non-prime numbers.
  • A participant introduces a generalization for finding \( n \) such that \( n, n+1, n+2, \ldots, n+k \) are all non-prime, particularly when \( k \) is prime.
  • Another participant provides an example with \( k = 11 \) and \( n = 2310 \), noting that while the method is straightforward, it can lead to longer sequences of non-prime numbers than expected.
  • Some participants mention \( x = 7! + 2 \) as another solution, detailing the divisibility of the resulting numbers.
  • A list of consecutive non-prime numbers is presented, demonstrating various examples and their factorizations.
Participants do not reach a consensus on a single method or solution. Multiple competing views and examples are presented, indicating that the discussion remains unresolved regarding the best approach or the smallest solution.
The discussion includes various assumptions about the properties of numbers and the conditions under which they are considered non-prime. The effectiveness of the proposed methods may depend on specific definitions and contexts.
Amer
is it possible to find a 6 Successive numbers like
x , x+1 , x+2 , x+3 ,x+4 ,x+5 such that one one is prime ?
Thanks
Mathematics news on Phys.org
Thanks
It is comfortable to verify that $x=5!=120$ satisfies the request... and the reason of that is easy to see...
Kind regards
$\chi$ $\sigma$
Of course $x=5!$ is not the only and neither the 'smallest' solution. Setting $x=90$ You have 7 consecutive non prime numbers...
Kind regards
$\chi$ $\sigma$
Why don't try to generalize the problem: given k, how to compute an n such that n, n+1, n+2,...,n+k are all non prime numbers?...
Kind regards
$\chi$ $\sigma$
An easy way to get the result in the particular case where k is prime is based on the consideration that $k|n \implies k|(n+m k)$. Setting $n = 2 \cdot 3 \cdot 5 \cdot ... \cdot k$ we are sure that $n+2,n+3,...,n+k+1$ are all non prime numbers. For example...
$\displaystyle k=11 \implies n=2310 \implies 2312,2313,2314,2315,2316,2317,2318,2319,2320,2321,2322\ \text{are all non prime }$
Although 'easy' this method is often 'excessive' because the effective quantity consecutive non prime numbers can be greater. In the given example 2311 is prime so that the sequence starts at 2312 but 2323,2324,2325,2326,2327,2328,2329,2330,2331 and 2332 are non prime numbers [2333 is prime...] and the effective sequence's length is 20 [not 11]...
Kind regards
$\chi$ $\sigma$
Thanks very much, you are amazing. (f)
Kind regards
$\chi$ $\sigma$
nice one I get it
n +2 = 2.3.4...k +2 = 2(3.4...k +1 ) not prime
n+3 = 2.3.4...k + 3 = 3(2.4...k+1) not prime
Thanks
Hello, Amer!
Is it possible to find a 6 consecutive integers numbers like
x , x+1 , x+2 , x+3 ,x+4 ,x+5 such that not one is prime? . Yes!
One solution is: .x \:=\:7!+2
. . \begin{array}{c}7!+2\text{ is divisible by 2} \\ <br /> 7!+3\text{ is divisible by 3} \\ 7!+4\text{ is divisible by 4} \\ <br /> 7!+5\text{ is divisible by 5} \\ 7!+6 \text{ is divisible by 6} \\ <br /> 7!+7\text{ is divisible by 7} \\ \end{array}There is a simpler (and much longer) list:
. . \begin{array}{ccc} 114 &amp;=&amp; 2\cdot57 \\ 115 &amp;=&amp; 5\cdot 23 \\ 116 &amp;=&amp; 2\cdot 58 \\ 117 &amp;=&amp; 3\cdot39 \\ 118 &amp;=&amp; 2\cdot59 \\ 119 &amp;=&amp; 7\cdot17 \\ 120 &amp;=&amp; 2\cdot60 \\ 121 &amp;=&amp; 11\cdot11 \\ 122 &amp;=&amp; 2\cdot61 \\ 123 &amp;=&amp; 3\cdot41 \\ 124 &amp;=&amp; 2\cdot62 \\ 125 &amp;=&amp; 5\cdot25 \\ 126 &amp;=&amp; 2\cdot63 \end{array}
soroban said:
Hello, Amer!
Thanks, and Hello :)
we can make a list with k numbers which are not prime like that
k! + i i=1,...,k
  • · Replies 24 ·
  • · Replies 48 ·
