60-80 mm refracting telescope for beginners
  • Context: Stargazing
  • Thread starter Thread starter FreeMitya
    Beginners Telescope
The discussion centers on selecting a beginner telescope, specifically recommending 60-80 mm refracting telescopes for novice astronomers. An 80 mm refractor is highlighted as a significant upgrade in optics and mount quality compared to a 60 mm model, with brands such as Celestron, Meade, and Orion suggested. Users can expect to see Saturn clearly, although details may be limited. Alternatively, a 6" Dobsonian telescope is mentioned as a superior option for similar pricing, providing better image quality. The conversation also touches on starting with binoculars, specifically the Orion Giant View 15x70, which requires a tripod for stability.
  • Understanding of telescope specifications, including aperture and focal length
  • Familiarity with brands like Celestron, Meade, and Orion
  • Knowledge of basic astronomy concepts, such as planetary visibility
  • Awareness of binocular usage and stabilization techniques
  • Research the differences between refractor and Dobsonian telescopes
  • Explore the features of the Orion XT8 Dobsonian telescope
  • Learn about the importance of tripod stability for binoculars
  • Investigate the impact of eyepiece quality on telescope performance
Beginner astronomers, hobbyists considering their first telescope, and anyone interested in understanding the basics of astronomical observation equipment.
FreeMitya
I posed this question in a thread in the GD forum because I had not yet seen this thread and, wretched creature that I am, I neglected the search tool. Anyway, regarding beginner telescopes, I thought some of you might be able to provide some insight. I read that a good beginner range is a 60-80 mm refracting telescope. How far and how clearly would an 80 mm be able to see? For example, how clearly would I be able to see Saturn (assuming good atmospheric conditions) with an 80 mm? Would I be able to see Titan as well? I define the word "novice" when it comes to telescopes and any help would be much appreciated.
Astronomy news on Phys.org
The smallest refractor you should get is a 70mm with a focal length greater than 700mm, IMO. The 60mm scopes available nowadays have truly horrible mounts and will really frustrate you. The 80mm scopes are a real step up in quality both in optics and the mount, so that is the one I would choose in the range you suggest. A decent 80 to 90mm achromatic refractor telescope (Celestron, Meade, Orion, Skywatcher, Explore Scientific, AstroMaster, etc...) will cost you from $150 to $500 depending on quality and the mount you choose. Those scopes will let you see Saturn fairly clearly but it (Saturn) will be small and you might not be able to make out some fine details. These scopes come with low cost diagonals and eyepieces which can affect the quality of the image you see.
For nearly the same money (~$300), you could get a much higher quality 6" dob that would give you much better images, IMO.
Thanks! I think you started typing your answer before I temporarily took my question down to search the thread. I got my answer, but I re-posted my question anyway to avoid confusion. My sights are currently set on the Orion XT8. There is a payment plan available for $120/month that seems like a really good deal.
Again, thanks for for your help.
FreeMitya said:
I've reconsidered and I think I'm going to go with binoculars to start my amateur astronomy journey. How do these look?
http://www.telescope.com/Binoculars...tronomy-Binoculars/pc/-1/c/5/sc/72/p/9327.uts
Those are good, but you're going to need a tripod to hold them, as 15x magnification is practically impossible to hold steady with just your hands. Binoculars are good for starters, as they generally have a wide field of view and don't require collimation or adjustments.
The tripod shouldn't be a problem.
  • · Replies 22 ·
53K
  • · Replies 35 ·
11K
20K
