6D numerical integration in Maple with nested infinite limits
17 replies · 6K views · last reply
hpriye
Hello
I have the following question in numerical integration in higher dimension. Any help/suggestion would be welcome.
The integral is ( I am using maple notation ):
int( int( int( int( int( int( f(x,y,z), z=-infinity..w), w=-infinity..infinity),
y=-infinity..v), v=-infinity..infinity),
x=-infinity..u), u=-infinity..infinity);
The integral is convergent. Indeed f(x,y,z) = K*exp(-( x^2+(y-x)^2+(z-y)^2) )/2), where K is a given constant.
Thanks in advance
Kind regards
hpriye
And you are asking about... ?
Could be I am missing something obvious, it happens, but I see only statements, no questions.
What is your question? Surely it is not just "how do you do a numerical integration"! That is much too broad.
I am sorry, I thought it obvious that I was asking for a numerical method for evaluating the 6 dimension integral.
Many thanks in advance
hpriye
Hmm..I would first restrict the infinity to a radial variable, i.e, switch to spherical coordinates and see what simplifications, if any, that would give me.
Ok. I tried the following transformation:
x = r*cos(theta)*cos(phi)
y = r*cos(theta)*(cos(phi) + sin(phi))
z = r*cos(theta)*(cos(phi) + sin(phi)) + r*sin(theta)
and the Jacobian is -r^2*cos(theta). This means I am retaining the variables u,v,w as they are.
Now the question: what are the limits for the six variables: r, theta, phi, u, v, w?
Another question: Is there a transformation for removing u, v, w from being present in the limits?
Kind regards and many thanks
hpriye
Hi hpriye! :smile:
The integral is over all x and u with -∞ < x < u < ∞, so:
[tex]\int_{-\infty}^{\infty} \int_{-\infty}^u f(x,y,x) dx du\ =\ \int_{-\infty}^{\infty} f(x,y,x)\left(\int_x^{\infty} du\right) dx\ =\ \infty[/tex]
or have I misunderstood the question? :confused:
More than misunderstanding I would say misreading :(
hpriye
tiny-tim said:
Hi hpriye! :smile:
i would use monte carlo integration. how about you write out your integral in tex so we can all understand it
Nope … can't be misreading …
'cos I don't read maple! :biggrin:​
… is it Canadian? :confused:
… i know tex is texan … :rolleyes:
∫_(-∞)^∞▒∫_(-∞)^u▒∫_(-∞)^∞▒∫_(-∞)^v▒∫_(-∞)^∞▒∫_(-∞)^w▒〖f(x,y,z) dz dw dy dv dx du〗
f(x,y,z)=1/〖√2π〗^3 e^(-1/2(x^2+(y-x)^2+(z-y)^2))-1/√6 e^(-x^2/2-y^2/4-z^2/6)
I have tried to give the MsWord 2007 format. Hope it is readable! Underscore stands for subscript and ^ stands for superscript
Kind regards
hpriye
in texas we say …
Kind regards
hpriye
Hi hpriye! :smile:
If you mean [tex]\int_{-\infty}^{\infty}\int_{-\infty}^u\int_{-\infty}^{\infty}\int_{-\infty}^v\int_{-\infty}^{\infty}\int_{-\infty}^w f(x,y,z)\,dz dw dy dv dx du[/tex]
[tex]f(x,y,z)\ =\ \frac{1}{(2\pi)^3} e^{-1/2(x^2+(y-x)^2+(z-y)^2)}\ -\ \frac{1}{\sqrt{6}}e^{-(\frac{1}{2}x^2\,-\,\frac{1}{4}y^2\,-\,\frac{1}{6}z^2)}[/tex]
it's:
[noparse][tex]\int_{-\infty}^{\infty}\int_{-\infty}^u\int_{-\infty}^{\infty}\int_{-\infty}^v\int_{-\infty}^{\infty}\int_{-\infty}^w f(x,y,z)\,dz dw dy dv dx du[/tex]
[tex]f(x,y,z)\ =\ \frac{1}{(2\pi)^3} e^{-1/2(x^2+(y-x)^2+(z-y)^2)}\ -\ \frac{1}{\sqrt{6}}e^{-(\frac{1}{2}x^2\,-\,\frac{1}{4}y^2\,-\,\frac{1}{6}z^2)}[/tex][/noparse]
Yes, exactly. But I observed square root symbol is missing, even in the original typesetting. It should be (sqrt(2*pi))^3. Thank you very much!
Kind regards
hpriye
tiny-tim said:
Hi hpriye! :smile:
it's:
hmm … so it's:
[tex]f(x,y,z)\ =\ \frac{1}{(2\pi)^\frac{3}{2}} e^{-1/2(x^2+(y-x)^2+(z-y)^2)}\ -\ \frac{1}{\sqrt{6}}e^{-(\frac{1}{2}x^2\,-\,\frac{1}{4}y^2\,-\,\frac{1}{6}z^2)}[/tex]
with an extra:
[noparse][tex]\frac{3}{2}[/tex][/noparse] :wink:
Hi hypre.
As you already know this task is not so simple to solve because of multi-integration. First it is very useful and not so painful see whether first integral exists: :smile:
[tex]\Theta(u,x,v,y,w)=\int_{-\infty}^{w} f(u,x,v,y,w,z) dz = \frac{1}{2}e^{-\frac{x^2}{2}-\frac{y^3}{4}}\;\sqrt{\pi} \left(1+Erf(\frac{w}{\sqrt{6}}) \right) + <br /> \frac{1}{4\pi}\; e^{-x^2+xy-\frac{y^2}{2}} \left(1+Erf(\frac{w-y}{\sqrt{2}}) \right)[/tex]
Integrals would exist if [tex]u,v,w \in (-\infty,0)[/tex] otherwise integrals diverge !
You can see that if above integral split on two integrals
[tex]\int_{-\infty}^{0} \Theta(u,x,v,y,w)\; dw = 0.586571 + O(10^{-6})[/tex]
[tex]\int_{0}^{\infty} \Theta(u,x,v,y,w)\; dw \rightarrow \bf{\infty}[/tex]
Trick how to see whether this exist to plot it. Put [tex]x=y=1[/tex] as you already know [tex]x \in (-\infty,\infty)[/tex] and [tex]y \in (-\infty,\infty)[/tex]. I made also graph so see what is the shape of function and is attached to this answer.
If you don't understand just send me email and I will try to explain.
Enjoy :smile:
MrSnoopy
  • Screenshot of a Mathematica notebook plotting a smooth increasing sigmoid curve from near 0 at x = -5 to about 0.93 by x = 5, with axes labelled from -10 to 10 and 0.2 to 0.8.
Sorry I forgot to mention numerical solution [tex]= 0.586571 + ...[/tex] comes form [tex]x=y=1[/tex]. It is only to see that first has numerical solution other diverge.
Thankyou very much for your efforts!
One important aspect of this integral is this: It belongs to a class of integrals which apparently diverge, but not in the real sense.
For example define two functions
[tex]f(x)\ =\ x^2 + e^{-x^2} \[/tex] and
[tex]g(x)\ =\ x^2 + e^{-2 x^2} \[/tex]
then individually the two integrals:
[tex]\int_{-\infty}^\infty f(x)\ dx[/tex] and [tex]\int_{-\infty}^\infty g(x)\ dx[/tex] diverge but [tex]\int_{-\infty}^\infty (f(x)-g(x))\ dx = \sqrt{\pi} - \sqrt{\frac{\pi}{2}}[/tex]
Similarly, the six-dimensional integral has another 3 dimension integral in the denominator (which I have not posted or mentioned earlier) such that the ratio is a finite number, in a limiting sense. I know this is a very very complicated integral, which naturally arises while solving problems in financial mathematics, so what I am interested in is, a numerical method to handle such integrals involving limiting case:
[tex]\lim_{a \rightarrow \infty} \left(\frac{\int_{-a}^a \int_{-a}^u \int_{-a}^a \int_{-a}^v \int_{-a}^a \int_{-a}^w \nu(x,y,z) \ dw\ dz\ dv\ dy\ dx\ du}{\int_{-a}^a \int_{-a}^a \int_{-a}^a \delta(x,y,z) \ dz\ dy\ dx} \right)[/tex]
Kind regards and thanks to one and all.
hpriye
No problem.
I would solved it by Simpsons method, has good accuracy at low number of steps. Don't forget functions are very quick :smile:
