A bullet from speeding to full stop.
  • Thread starter Thread starter chawki
    Bullet
20 replies · 3K views · last reply
chawki
A bullet (mass 15 g) moving at a speed of 425 m/s is brought to a stop in 3.5 cm in a block of wood.
Find the force on the bullet, assuming that it is constant.
what law should we use?
0 - 1/2*m*V^2 = m*g*0.035 + F*0.035 ?
Explain why you think that the gravity force does work.
Wow. I think i was wrong...it doesn't have work because the motion is on X axis, not Y axis.
so i think we will have only: - 1/2*m*V^2 = F*0.035 ?
yup! :smile:
But then we will get F=-38705.35N
How is possible to have a negative value!
Force is a vector, that has both magnitude and direction. The negative sign implies that if the bullet is moving from left to right, in the positive x direction, then the force acting on it is in the opposite (negative x) direction, from right to left, acting to slow it down.
Ok, so F=-38705.35N is correct ?
And thank you everyone, I'm learning new things :)
no, the question is either asking for the magnitude of F, which is always positive, or it's asking for a "vector" description of F, which means a magnitude and a direction
(oh, and far too many significant figures :redface:)
yeees …
but what did i say about the significant figures?
hmm …
how many significant figures are there in the question?
so how many do you think there should be in the answer? :smile:
I never ever used these things of significant figures...that's why I'm all confused
tiny-tim said:
hmm …
There are three? so the answer would be 38705.357N?
chawki said:
There are three?
no, the question gives m v and d to 3 and 2 significant figures …
so the answer is probably best in only 2 sig figs
… so the answer would be 38705.357N?
are you even trying? :redface:
how would you write 38705.357 to 3 sig figs?
how would you write 38705.357 to 2 sig figs?
(if you don't know how, then look it up)
yes, to 3 significant figures it's 38700, to 2 it's 39000
we can write also: - 1/2*m*V^2 = -F*0.035 knowing that F will be from right to left, opposite the bullet direction and then we will find F the same. no need to introduce the magnitude.
