A circular loop over a magnetic field directed outwards
11 replies · 9K views · last reply
Astraithious
There is a counterclockwise current I in a circular loop of wire situated in an external magnetic field directed out of the page as shown. The effect of the forces that act on this current is to make the loop
Circular loop of wire carrying a counterclockwise current I, surrounded by dots representing a magnetic field pointing out of the page, labelled Magnetic Field.
Select one:
a. expand in size X
b. contract in size
c. rotate about an axis perpendicular to the page
d. rotate about an axis in the plane of the page
e. accelerate into the page
Right hand rule is all that is needed
So I got this wrong for reasons I am unsure of, however this is my reasoning for choosing aThe right hand rule has many variations but this is the one i learned
My thumb is in the direction of Current or Velocity
My fingers point in the B Field direction
My palm then is the direction of the forceI can use this at any point on the circle and it pushes outwards, so should try and expand the loop right?The reasoning behind my answer being incorrect.
"The external field has lines running out of the page, which we can think of as a North pole being just under the page. The current in the wire, obeying the RHR, effectively makes a magnetic field that also has lines running up out of the page. This means that the above page part is like a north pole and the below part is like a south pole. Since this south will be attracted down by the external field north, there is an accelerating force downwards into the page."
I somewhat understand what this answer however I do not find any force directed down, is this not why things levitate when above high powered fields?
Do you know the right answer ? Sorry I asked a stupid question.
Definitively no, but I know that to me and everything else I read about this problem says it expands and I agree.
I would like to know why my teachers answer is not correct. My only guess for this is the the movement is in the direction of the of the magnetic field and it should be parallel I believe.
Diagram of a circular loop carrying a counter-clockwise current I, surrounded by a grid of dots representing a magnetic field pointing out of the page, labelled Magnetic Field.
Select one:
a. expand in size X
b. contract in size
I think your answer A is correct. Use the Lorentz Force: F = qv X B. The positive current points counter-clockwise, and the B field is up out of the page. When I use the right-hand rule, I point my right hand fingers in the direction of qv and then curl them in the direction of B. My thumb points in the direction of the force F, which pulls outward on the circular wire.
I agree with berkeman and you.
By any chance, was your instructor referring to the direction of electron current, rather than conventional current ?
Your answer (a) is correct. There can be no force on the coil in the into-out-of-page direction since that's the direction of the B field. F = i dl x B so F can never have a B-direction component.
The offered argument is wrong also. Yes, there is a N pole behind the page and a S pole in front of the page, but the coil produces a S pole behind the page and a N pole in front.. Not that that's particularly relevant here.
It wouldn't have made any difference.
It does make a difference.
If the electrons are flowing in a counter-clockwise direction, then the loop will tend to shrink.
Of course. But the given answer (in bold in post 1) is still wrong.
I gave up trying to talk sense into her, its an online course to upgrade and I suppose the one mark is fine. She couldn't justify her answer she just said that's the answer given. thanks anyhow everybody
Hope that is not representative of physics instructions in this country today. We've dumbed-down in too many ways already.
It's understandable for a teacher to give a wrong answer.
However, when confronted with the correct solution, the teacher would hopefully be able to recognize it's correctness. Lacking that, the teacher should look further into the problem and consult a more enlightened source. A response like "that's the answer given" or "that's what the solution manual says" with no further investigation, is unforgivable.
