A Couple More Simple Think critically and Explain Questions
  • Thread starter Thread starter emma123
    Couple Explain
The discussion focuses on understanding key electrical concepts related to resistance, current, and types of current in different applications. A low resistance in an extension cord is crucial for electric heaters to prevent overheating and power loss. When comparing light bulbs, the current at 220V will be less than at 110V, specifically half as much due to the relationship between voltage and current. In a 60 Hz alternating current, electrons change direction 120 times per second. Lastly, automobile dome lamps typically use direct current (DC), while home lamps generally use alternating current (AC).
emma123
Think and Explain
1. Why is it important that the resistance of an extension cord be small when it is used to power an electric heater?
2. Will the current on a light bulb connected to 220V be more or less than when the same light bulb is connected to 110V? How much?
3. In 60- Hz alternating current, how many times per second does the electron change its direction? (Don't say 60)
4. Would you expect to find DC or AC in the dome lamp in an automobile? In the lamp in your home?
Please help on these questions I would appreciate it very much THANKS!:smile:
Not to be rude but, you do realize you have to put some work into it before anyone will help you.
oh sorry about that, but i did try to do them myself but i didn't understand them so i decided to skip them move on and then go back to try to figure out the answers for these few problems but i couldn't so I decided to post them up as well
emma123 said:
Think and Explain
Have you learn about power in an electric circuit? Do you know what it means to have a 60 Hz AC current?
Pat
