A good quantum number for Cnv symmetry?
The discussion revolves around the possibility of defining good quantum numbers in systems with discrete cylindrical symmetry, specifically Cnv symmetries, in the context of solid state physics and chemistry. Participants explore the relationship between angular momentum and symmetry, and whether operators can be defined that commute with the Hamiltonian to yield quantum numbers analogous to L_z.
  • Some participants inquire about defining good quantum numbers for Cnv symmetries, drawing parallels to angular momentum in spherical and cylindrical symmetries.
  • One participant suggests that for C2v symmetry, the Hamiltonian commutes with the 180-degree rotation operator, implying the potential for good quantum numbers.
  • Another participant discusses coupling discrete angular momentum with spin projection and questions the derivation of eigenstates of the Hamiltonian in this context.
  • A participant expresses confusion regarding the relationship between spin-orbit coupling in molecules versus solids and the implications for defining quantum numbers.
  • One participant describes a specific approach from a textbook that couples angular momentum in nanostructures, noting that while a good quantum number F may not exist, its projection F_z could be relevant.
  • Another participant acknowledges the complexity of the inquiry and suggests that F_z is unlikely to be a good quantum number, drawing an analogy to symmetry breaking in crystal fields.
Participants express differing views on the existence and definition of good quantum numbers in the context of Cnv symmetries, with no consensus reached on the applicability of existing theories or methods to the specific case of nanostructures.
Participants reference various texts and concepts, indicating that the discussion may depend on specific definitions and assumptions about angular momentum and symmetry in quantum mechanics, which remain unresolved.
Amentia
Hello,
I was wondering if it was possible to define good quantum numbers in solid state physics or chemistry when systems posses a discrete cylindrical symmetry Cnv. I know that in terms of angular momentum, L and L_z will be good quantum numbers for spherical symmetry, then only L_z is a good quantum number for cylindrical symmetry.
What about C2v, C3v, etc.? Is it possible to define an operator which commutes with the Hamiltonian and provide a quantum number similar to L_z?
I am sorry if this is common knowledge but I have not found the answer on the internet nor in the textbooks I know of.
Thanks for your help!
Of course. A ##C_{2v}## molecule is symmetric under a ##180^{\circ}## rotation about the symmetry axis, so the Hamiltonian commutes with the ##180^{\circ}## rotation operator. Tinkham’s book on group theory in quantum mechanics is a good resource.
Thank you for your answer. When you use group theory and couple this discrete angular momentum with the spin projection, ##L_{z}(180^{\circ})+S_{z}##, is there a way to define the eigenstates of the Hamiltonian? I am used to couple L+S for L=1 and S=1/2 in semiconductor physics to obtain J=3/2 and J=1/2 states that define heavy-hole, light-hole and split-off. In some textbooks, they take only J_z as a good quantum number to define some new set of states.
I have Tinkham's book but I don't remember seeing a derivation of this procedure. Are you recommending the book in general or thinking to a specific chapter?
I guess I’m confused about what you’re asking. Are you thinking about spin-orbit coupling in molecules vs solids? Or maybe spin-rotation coupling like we see with spin isomers of hydrogen?
Sorry I tried to stay general as I was thinking it would be easier for people to answer but I guess it makes everything confusing.
I am thinking about nanostructures where you have a part of the wave function which is a Bloch state (like in regular solid state physics) and a second part which is an envelope function. So the Bloch state basis is already ##J=L+S## and then the envelope has also some angular momentum ##L_{env}##.
In the book The k.p Method by Lok Lew Yan Voon and Morten Willatzen, they first assume a spherical symmetry and say they can now couple ##J## to ##L_{env}## and generate a new good quantum number ##F## by the usual composition of angular momentum rules with Clebsch-Gordan coefficients.
Then, they consider systems with cylindrical symmetry and say ##F## is not a good quantum number anymore but we can keep its projection ##F_{z}##. Then they find that for a quantum wire for example you can write the wave function as ##|\psi_{F_{z}}\rangle = \sum_{J_{z}}C_{J_{z},F_{z}}|\frac{3}{2},J_{z}\rangle\otimes|F_{z}-J_{z}\rangle##.
Actual nanostructures can have "discrete" cylindrical symmetry like ##C_{2v}## and I was wondering if their approach could be extended to find a good quantum number, basis states... If I write the rotation operator for ##C_{2}## in the cylindrical case, I would use ##exp(i\pi F_{z}/\hbar)## but ##F_{z}## is not supposed to be a good quantum number anymore.
I hope what I am trying to understand is better explained. I am sure it must be taught in group theory books somewhere as you hinted if it has been done before in other cases. But my first question is really: is it possible?
Ah ok, yes it's much clearer what you're after now. Unfortunately, I don't have anything really insightful to say about it. I imagine it will be analogous to the symmetry breaking seen with an atom in a crystal field. ##F_z## definitely won't be a good quantum number, though. I'll think more about it if I get a moment.
  • · Replies 18 ·
  • · Replies 26 ·
