How Do You Simplify the Expression \(\frac{a^4-b^4}{4a^2+4b^2}:(a+b)\)?
  • Thread starter Thread starter kristo
    Simplifying
The discussion revolves around simplifying the expression \(\frac{a^4-b^4}{4a^2+4b^2}:(a+b)\). Participants clarify the meaning of the colon, suggesting it indicates division rather than multiplication. There is confusion over the correct interpretation of the expression, with one user asserting that the answer provided earlier is incorrect. A hint is given to simplify both the numerator and denominator of the fraction. Ultimately, the conversation highlights the importance of showing work when seeking help in mathematical problems.
kristo
I'm supposed to simplify this, help please!
Sorry for posting in the wrong section, could someone move it?
Welcome to PF, kristo.
According to forum guidelines, you need to show you work before asking for help.
the result will be: (a-b)/4
Normally, I would delete a post giving the answer while the original poster has not shown any effort on the problem, especially when there is no work done. Here, however, there is no difficulty since the "answer" given by sutupidmath is obviously wrong!
Kristo, what does that ":" mean? Are you simply multiplying the fraction by (a+ b)? I will give a hint- you can both numerator and denominator of the fraction.
I appologize for entering the answer directly. However if ":" on kristos problem means division then i do not see why my answer is wrong?
I didn't think of : meaning division- you think it is missing a -?
In that case I can see your answer- although the usual interpretation of
a+ b/4 would be a+ (b/4)- still not right!
I think he meant division in the way ratios are written. 2:3, for example.
