A problem on filtering a solution of acid and solid particles
The discussion centers on a challenge involving the filtration of solid particles reacting with acid in a stirred batch reactor. The solid particles, sized between 150-250 microns, need to be quickly separated from the liquid without losing their shape. A centrifuge is suggested, but the user expresses concerns about its availability and potential impact on particle integrity. The idea of warming the mixture to enhance separation is also considered. The conversation highlights the need for effective filtration methods that preserve the physical properties of the solid particles.
pippobaudo
Hello everybody, I have the following problem: I have a batch reactor were I have solid particles reacting with acid. The reactor is stirred. The solid particles are in the range 150-250 micron. I'd like to let them react for a short time, and then quickly remove the liquid face and dry up the solid particles. If I use a normal filter the particles will be attached to the filter and difficult to remove.
If you have any ideas please contact me.
Dino.
Can you use a centrifuge?
Hello and thanks for the answer,
no i guess the centrifuge is not available here and i don't know if it would be good to use that since I'd like the particle to conserve their shape. May be I should warm up a bit and increase the surface to separate the water. I will think about it
What mathematics software should engineering students use? Is it correct that much of the engineering industry relies on MATLAB, making it the tool many graduates will encounter in professional settings? How does SageMath compare? It is a free package that supports both numerical and symbolic computation and can be installed on various platforms. Could it become more widely used because it is freely available? I am an academic who has taught engineering mathematics, and taught the...
  • · Replies 18 ·
  • · Replies 28 ·
24K
  • · Replies 19 ·
  • · Replies 62 ·
11K
