A problem on quadratic equations .
33 replies · 6K views · last reply
PeterO said:
You could have supplied a clear/concise solution to "similar" problem with different sized beakers as a guide to how such a question is solved.
People of different age need different explanation. If you need help to find a general solution to similar problems on your level of knowledge, I show you:
Assume you have two beakers P and Q. The volumes are Vp and Vq, both beakers are filled with a mixture of two fluids, "1" and "2". The concentrations of one of the components in the vessels are p and q, respectively. Assume that mixing of the components preserves the volume, that is, the volume of a mixture of v1 volume of component 1 and v2 volume of component 2 is v1+v2.
Taking x volume from both beakers and mixing them, the concentration of this sample is 0.5(p+q)
Returning x l of this mixture to beaker P, the new concentration p' becomes:
p'=[p(Vp-x)+0.5(p+q)x]/Vp=p+0.5(x/Vp)(q-p)
Returning x l of the sample mixture to Q, the new concentration q' becomes
q'=[q(Vq-x)+0.5(p+q)x]/Vq=q-0.5(x/Vq)(q-p)
In case of subsequent mixing steps you have the recurrence relations between concentrations:
p(n+1)=p(n)+0.5(x/Vp)(q(n)-p(n))
q(n-1)=q(n)-0.5(x/Vq)(q(n)-p(n))
I hope this is enough help for you to solve the original problem.
ehild
Assume you have to beakers P and Q. The volumes are Vp and Vq, both beakers are filled with a mixture of two fluids, "1" and "2". The concentrations of one of the components in the vessels are p and q, respectively. Assume that mixing of the components preserves the volume, that is, the volume of a mixture of v1 volume of component 1 and v2 volume of component 2 is v1+v2.
ehild
Yeah, right; I am sure that is much simpler to follow.
ehild said:
Sankalpmittal, you were almost at the end. You should not have given up.
Well, you determined correctly the amount of acid both in P and in Q after the first step of mixing. Taken out x l from both beakers and mixed, then returned x l back to each beakers, the amount of acid was x/2 l in P and 40-x/2 l in Q.
In the next step, x l is removed again from both bakers. The sample from P contains x2/100 l acid, and that from Q contains (40-x/2)x/40=(80x-x2)/80 l acid. The two samples altogether contain
x2/100+ (80x-x2)80= (400-x2)/400 l acid.
This mixture is halved and one half is returned to beaker P, the other to Beaker Q. The amount of acid in each half is
(400-x2)/800 l.
(You were here, making only a little mistake.)
As x2/100 l acid has been removed from beaker P at the beginning of the second mixing step, it contains
(x/2-x2/100) l
acid in the (50-x) l solution. Now x l mixture is returned, with (400x-x2)/800 l acid content. So the total amount of acid becomes
[tex]x/2-x^2/100+(400x-x^2)/800=\frac{400x-8x^2+400x-x^2}{800}=\frac{800x-9x^2}{800}[/tex].
This amount is given in the problem, it is 71/8 l.
So your quadratic equation is
[tex]\frac{800x-9x^2}{800}=\frac{71}{8}[/tex]
Can you continue from here? Have you learned solving quadratic equations?
You will get two roots, but one is physically meaningless. Let me see what you get for x. I am not allowed to give full solution.
ehild.
9x2-800x+7100 = 0
9x2-90x-710x+7100=0
9x(x-10)-710(x-10)=0
(x-10)(9x-710)=0
These are the two roots of equation . The second root isn't possible because the value exceeds 50 . So the appropriate answer is that x is equal to 10 l .
Yes , I have learned quadratic equations in class 8th . This question was rather different though .
ehild
Hm. This part is something which I am unable to understand. Your previous train of thoughts was easier to follow.
Thanks !
Well done! And you are right, it was a difficult problem, something for people over 18... Now you can teach your teachers how to solve such problems of mixing :wink:
The other method was for PeterO, he felt it easier than the one I showed to you.
ehild
