A pulley with rotational inertia
The discussion focuses on calculating the rotational acceleration and speed of a pulley with a rotational inertia of 2.0 x 10-3 kg·m2 and a radius of 20 cm, subjected to a time-varying tangential force F = 0.50t + 0.30t2. At t = 4.0 s, the correct rotational acceleration is determined to be 680 rad/s2, and the rotational speed is calculated using integration, yielding a value of 10.4 rad/s. The initial miscalculations stemmed from incorrect assumptions about constant angular acceleration.
  • Understanding of rotational dynamics and torque calculations
  • Familiarity with the concepts of angular acceleration and rotational inertia
  • Knowledge of calculus, specifically integration techniques
  • Basic physics principles regarding forces and motion
  • Study the principles of rotational dynamics in-depth, focusing on torque and angular acceleration
  • Learn about the integration of force functions to determine rotational speed over time
  • Explore advanced topics in dynamics, such as non-constant angular acceleration
  • Practice problems involving pulleys and rotational motion to solidify understanding
Students studying physics, particularly those focusing on mechanics and rotational dynamics, as well as educators seeking to clarify concepts related to pulleys and angular motion.
soccer_09
A pulley, with a rotational inertia of 2.0 10-3 kg·m2 about its axle and a radius of 20 cm, is acted on by a force applied tangentially at its rim. The force magnitude varies in time as F = 0.50t + 0.30t2, where F is in Newtons and t in seconds. The pulley is initially at rest.
(a) At t = 4.0 s what is its rotational acceleration?
1 rad/s2
(b) At t = 4.0 s what is its rotational speed?
2 rad/s
Torque = I * alpha
Torque = |r||F|sin(theta)
I have only tried part a. What I did was since I know the radius = .020 m, F, and I, I rearranged the formulas like so:
alpha = Torque / I
Since it's tangent, sin(90) = 1 therefore Torque = r*F
F at 4s = 6.8 N and multiplying this by the radius .020 m gives a torque of .136 Nm
So now alpha = .136 Nm / .002 kgm^2 = 68 rad/s^2
I plugged that in on webassign and it was wrong so apparently I'm not doing something right. Any guidance is appreciated, thanks.
Your method for calculating the angular acceleration is correct. However 20 cm = 0.20 m not 0.02 m.
Yep, I had a friend tell me I converted incorrectly. Thanks :)
From there though, my alpha = 680 rad /s^2
The equation for rotational veloctiy is:
omega(t) = omega (initial) + alpha (t)
so with alpha = 680 rad/s^2 and t = 4s that should give me a rotational speed of 2720 rad/s
This, however, is incorrect as well. The initial omega = 0 rad/s because the pulley is initially at rest. What am I doing wrong here??
The equation omega(t) = omega (initial) + alpha (t) only works for constant angular acceleration. Here, force is F = 0.50t + 0.30t2, so alpha can't possibly be constant. You'll have to use integration to get the speed.
Thanks :) I integrated from 0 to 4 of F(t) and got 10.4. using the constants I and R, I was able to get the correct answer. Thanks again.
  • · Replies 30 ·
14K
