A query in integration using method of substitution
7 replies · 2K views · last reply
Insights Author
:[/B]
I was learning the use of standard forms in method of substitution in solving integration. My book has given this method for solving integrals of the type ##\int \frac{lx +m}{ax^2+bx+c} dx##:
As an example, the book gives this one:
:[/B]
How does one solve to get the circled part? I can understand that the book is separating the two parts of the numerator. I also know how to solve the second part, but how does one reach the circled part?
Arman777 said:
For ##k_1\int \frac {2ax+b} {ax^2+bx+c}\, dx## you need another substitution.
Even I was thinking that. How do I solve that part: ##k_1 \int \frac{2ax +b}{ax^2+bx+c} dx##? As per the book, I do not require another substitution. So, how should I proceed with that part?
Searching the Internet for something called an "integral calculator", I found one, and it showed me the steps properly:
This solves my problem. The book had done it in one step, which is why I was facing the problem.
It's nice but it would be better If you work by yourself and find the solution. Anyways yes, that's how you do it.
When you are a beginner, just starting to learn the subject, you should avoid such on-line tools (except, possibly to check your work). You will never figure out how to do integrals without doing lots of examples by hand and without assistance from computer-aided integration tools. Think of it this way: what would you do on an exam, where you have no access to such facilities?
I solve problems from at least two books before proceeding to a new topic. Help materials like online calculators help in self study and nothing else, especially when you're stuck at a problem you just can't solve.
The expression to be integrated is a linear function divided by quadratic. A linear function is the derivative of a quadratic. So if you were lucky the numerator would be the derivative of the denominator, i.e. the expression to be integrated wrt x would be ##\dfrac {f'\left( x\right) }{f\left( x\right) }## which I presume you know how to do. In this case we are as usual not so lucky, but we can make it into a linear part which is part which is derivative of the denominator (just hammering the constants) with some other constant leftover – that second part then being a constant divided by a quadratic which we know how to integrate. Well actually many people would think that second part is the most difficult one.
