A question about charged particle in a magnetic field
In summary, when a molecule in our surrounding air is ionized and given a mechanical velocity in addition to its random velocity due to temperature, its motion in a uniform magnetic field will be helical, with the component of velocity parallel to the field remaining constant and the molecule moving in a circle in the plane perpendicular to the field. This behavior applies to both single molecules and streams of ionized air. The magnetic field will not eliminate the random movements of the molecules, but rather cause them to move in a helical path. This was discovered by Boltzmann, who studied the emergent thermodynamic properties of large collections of particles. If the component of initial velocity parallel to the B field is zero, the motion will be circular. In general
T C
320
TL;DR Summary
We all know how charged particles in motion behave in magnetic field perpendicular to it. Now, let's choose a molecule from surrounding air at ambient temperature, somehow ionize it and give some velocity and put it into a magnetic field. I want to know what will happen to the random velocity that it already possesses due to its temperature.
Suppose a molecule from our surrounding air (at ambient temperature) is being selected and is ionized. By some mechanical means, some velocity (say 100 m/s) is added to it and it has been put into a magnetic field perpendicular to its direction of motion. We all know how the molecule will behave in the magnetic field. But, my point is, in addition to the 100 m/s velocity "gifted" to it, it already contains some random velocity that is available to it by virtue of its temperature. As for example ,a Nitrogen molecule at 27°C or 300 K is 516.963 m/s. I want to know what will happen to this kinetic energy. Will this just add to "gifted" kinetic energy of the molecule and increase the velocity of the molecule towards the previous direction or something else will happen.
This is just to understand the behavior of a stream of ionized air being released to a magnetic field perpendicular to the direction of motion of the flow. What will happen to a single molecule will be applicable for a stream too.
The motion of a single charged particle in a uniform magnetic field is in general a helix. The component of its velocity in the direction of the field remains constant. And, it moves in a circle in the plane perpendicular to the magnetic field (assuming it has an initial velocity component in this plane).
Likes protonsarecool, russ_watters, Ibix and 2 others
PS the magnitude of its velocity will remain constant and not change when the field is turned on.
Likes vanhees71
@Baluncore, I know about MHD Generators. I just want to know whether they, especially the magnetic part is capable of converting the internal energy of the flew gas too or it just converts the velocity of the flow into useful power. To be more precise, whether the magnetic field will force the random movement of the ionized molecules to be streamlined in a direction perpendicular to magnetic field or they will remain unchanged?
Magnitude can't be changed because that means because energy can't destroyed. I want to know whether the ionized molecules will still contain the random movements or they will become streamlined perpendicular to the magnetic field?
The random movements are due to collisions with other molecules. Those collisions will still take place in a magnetic field. In a uniform magnetic field the motion between the collisions will be helical, rather than linear.
The helical movement will only occur when the direction of motion is perpendicular to the magnetic field. Will there be any helical motion where the direction of motion isn't perpendicular to the magnetic field?
The velocity of a single particle can't be random by definition. Temperature is proportional to the average kinetic energy in the random motion of many particles that collide with each other. A single particle doesn't have temperature, it has kinetic energy. If it never collides with something else, and if it is not subject to external forces, it's velocity continues forever according to Newton's First Law.
Such was the genius of Boltzmann. He discovered the emergent thermodynamic properties of large collections of particles that are not present in individual particles.
Likes russ_watters
Helical motion is the general case. If the component of velocity parallel to the field is zero, you have circular motion. If the components of velocity perpendicular to the field are zero, you have linear motion.
Circles, lines and no motion could all be considered degenerate helices.
Likes Dale and vanhees71
No, that'd be circular motion. Helical motion happens when there's a component of initial velocity parallel to the B field. That component is unaffected by the B field, while the components perpendicular to the field rotate.
Likes Dale, vanhees71 and PeroK
It has the magnetic field. Does that can change its direction of motion? Suppose the the direction of motion isn't perpendicular to the magnetic field but rather at an angle to it.
What will happen if neither of them is zero?
How the motion will look like then?
A helix, as @PeroK said in the post you quoted.
Likes Vanadium 50 and PeroK
Ok. Now, I understand. But, the actual movement is along the axis of the helix. So, ultimately it will look like a number of helical motions having same axis buy varying radius, right?
That's not a helix, that's a helter-skelter!
Ah, you mean of it's involved in random collisions, yes.
Well, lots of helices having parallel axes. There wouldn't be a bulk rotation around some particular axis, unless there's some carefully constructed non-uniform magnetic field and ion velocity profile that does that.
Likes PeroK
But, such collisions are only possible when the diameter of the rotation would be more than the mean free path, right? And at least it's clear now that the randomness of the motion is less in comparison to the scenario without the magnetic field.
Yes, that can be understood. But all axis are perpendicular to the direction of the magnetic field. And what about the particles/ions that entered the magnetic field at an angle >180 degree? My common sense tells me that they will go backward and collide with other ions and thus there would be transfer of momentum.
And last but not the least, suppose the ion flow has entered a MHD generator. In that case, the the perpendicular velocity components of the ion velocities will be converted to the electricity and there will be slowing down in the direction perpendicular to the magnetic field. What will happen to the rotational part of the particles/ions?
I have just done some calculations and found that if the Magnetic field is 3 Tesla, then the radius of curvature would be far greater than the mean free path. So there will be collisions. In a little bit different way, but the ultimate goal would be the same as neutral atoms.
It is always good to look at the numbers, but I don't see how it makes any difference. Particles moving randomly on various helical paths will not a priori be different from their straight line cousins in this context.
Likes russ_watters and Vanadium 50
Not "Various" helical path. All helix have the axis pointed towards the same direction. If the radius of curvature is less than that of the mean free path, there would be little chance of any collision. Collision will occur as the radius of curvature is much much greater than the mean free path. At the specified temperature above, the mean free path is 176.35 nm, while the radius is 0.07 meter, much much higher. By the way, I have considered the magnetic field to be 0.2 Tesla.
But the size of the helices as well as their centerline positions will be randomly distributed. I think it will not really matter but I applaud putting in the numberrs, obviating the discussion.
All helices have their axis aligned with the magnetic field. What will differ is the radius of rotation and linear velocity as different atoms have different level of energies.
Correct. But there will be no imparted drift.
hutchphd said:
imparted drift
What you want to mean by that?
I believe that, absent boundary effects, imposition of a uniform magnetic field on randomly moving charges willl induce no preferred instantaneous velocity direction.
Thread closed temporarily for Moderation...
Thread will remain closed. OP is not very forthcoming about their reasons for these posts, which makes it hard to offer quality technical help.
1. What is a charged particle in a magnetic field?
A charged particle in a magnetic field refers to a particle that has an electric charge and is subjected to the influence of a magnetic field. This can include electrons, protons, and other subatomic particles.
2. How does a magnetic field affect a charged particle?
A magnetic field causes a force to act on a charged particle, causing it to move in a circular or helical path. The direction and magnitude of this force depend on the charge and velocity of the particle, as well as the strength and direction of the magnetic field.
3. What is the equation for the force on a charged particle in a magnetic field?
The force on a charged particle in a magnetic field can be calculated using the equation F = qvBsinθ, where q is the charge of the particle, v is its velocity, B is the strength of the magnetic field, and θ is the angle between the velocity and the magnetic field.
4. How does the direction of the magnetic field affect the motion of a charged particle?
The direction of the magnetic field determines the direction of the force on a charged particle. If the magnetic field is perpendicular to the velocity of the particle, the force will be perpendicular to both and cause the particle to move in a circular path. If the magnetic field is parallel to the velocity, the force will be zero and the particle will continue in a straight line.
5. What is the significance of a charged particle in a magnetic field?
Charged particles in a magnetic field play a crucial role in many natural phenomena and technological applications. They are involved in the functioning of motors, generators, and particle accelerators, as well as the formation of auroras and the behavior of charged particles in space.
  • Classical Physics
  • Classical Physics
  • Electromagnetism
