A question about Dirac's quantization
  • Thread starter Thread starter kakarukeys
    Quantization
Dirac's method of quantization involves constraints represented as weak equalities, denoted by \(\phi_m \approx 0\), which indicates that these constraints are only valid on a specific submanifold of phase space. The discussion emphasizes that one must evaluate Poisson brackets before substituting these constraints, as substituting prematurely can lead to incorrect results. Weak equality means that two functions are considered equal only when evaluated on the constraint surface, distinguishing it from strong equality. The conversation also touches on the implications of this notation and its necessity in maintaining mathematical rigor in quantum mechanics. Understanding this distinction is crucial for correctly applying Dirac's quantization framework.
kakarukeys
In his book Lectures on Quantum Mechanics,
Dirac gives his way of quantizing system with contraints.
I do not understand the use of weak inequality in some equations.
C \approx 0
What is that for?
I've been slightly confused by this too, but my understanding of it is that while the \phi_m may equal zero, their derivatives perhaps don't... For this reason then, the quantity \left[g,\phi_m\right] (e.g. in equations 1-15, 1-17 to 1-19) would be trivially zero if you plug in \phi_m=0, however if you examine the Poisson bracket you actually have
\left[g,\phi_m\right] = \frac{\partial g}{\partial q_n}\frac{\partial \phi_m}{\partial p_n} - \frac{\partial g}{\partial p_n}\frac{\partial \phi_m}{\partial q_n}
and this is not necessarily zero. Writing the constraint equations as \phi_m\approx0 is just supposed to serve as a reminder not to substitute \phi_m=0 into your equations until after you've evaluated any Poisson brackets.
No, weak egaility means that, if 2 phase space functions are weakly equal
F\approx G
, it means that they're equal when evaluated on the surface of all constraints. Denoting this surface by \phi_{\Delta}=0 , we have BY DEFINITION
F\approx G \Leftrightarrow F|_{\phi_{\Delta}=0}=G|_{\phi_{\Delta}=0}
Daniel.
F\approx G
Daniel.
That doesn't seem to be exactly what Dirac is getting at in his book. He says:
P.A.M. Dirac said:
We have the constraints (1-4) [\phi_m(q,p)=0] but must not use one of these constraints before working out a Poisson bracket. If we did we would get the wrong result. So we take it as a rule that Poisson brackets must all be worked out before we make use of the constraint equations. To remind us of this rule in the formalism, I write the constraints (1-4) as equations with a different equality sign \approx from the usual. Thus they are written
\phi_m\approx0.(1-20)
I call such equations weak equations, to distinguish them from the usual or stong equations.
So he actually has the constraints weakly equal to zero, not functions evaluated on surfaces of all constraints. He also explicity says that while the constraints are equal to zero, this substitution must not be made until after the Poisson brackets have been evaluated. I mean, I guess we could say
\phi\approx0 \Leftrightarrow \phi|_{\phi=0}=0|_{\phi=0}
but I'm not sure how useful that is. Or am I completely misinterpreting Dirac when he says that the only reason to use \approx is to remind us that we must evaluate Poisson brackets before using the fact that the constraints are in fact equal to zero?
I've given you the definition for the weakly equality
One writes the finite countable set of all constraints
\phi_{\Delta}\approx 0
, instead of \phi_{\Delta}=0 to specify that the expressions \phi_{\Delta}\left(q,p\right) equal zero NOT on the entire phase space, but only on the submanifold of all constraints.
As for the definition of weak equality between 2 arbitrary functions defined on ALL phase space, it is given two posts above.
There's a theorem whose result is used to establish the following connection between strong equality and weak equality
F (q,p)\approx G(q,p) \Longleftrightarrow (F-G) (q,p)=c^{\Delta}(q,p) \phi_{\Delta}(q,p)
Daniel.
C \approx 0
What is that for?
Dirac quantization method is not completely rigorous (the deformation quantization is actually considered as the most accomplished one).
For the ones who are interested on a good compilation of the different quantization methods, I recommend the excellent and impressive paper (which also indicates the problems/restrictions associated with some methods):
Quantization methods: a guide for physicists and analysts, S. Twareque and M. Englis, math-ph/0405065.
Seratend.
P.S. I wish I would like to have an analogue paper for the different formulations of QM : )
I accept that you've given a definition of a weak equality... I just still am not sure that it is the same as the one Dirac uses in his book. He specifically states that the notation is solely as a reminder, not some mathematical formalism.
This is the part that confuses me - I thought that setting \phi_m=0 was the constraint. That is, we constrain that it must be zero. If you are saying that the phi equal zero only where they equal zero, then I agree, but do not understand why that statement requires a new symbol for equality...
Daniel.
Don't suppose you want to define what c^{\Delta} is? Or what happens when F=\phi and G=0, which is the example we are discussing here? In that case it seems that you just get
\phi_{\Delta}(q,p)\approx0 \Longleftrightarrow \phi_{\Delta}(q,p)=c^{\Delta}(q,p)\phi_{\Delta}(q,p)
which seems to imply that c^{\Delta}\equiv1 and that everything is weakly equal to zero since everything is equal to itself... But that doesn't tell me anything useful - anything is equal to itself times the identity, so why does this statement require a different symbol for equals than the standard '='? Perhaps I should also confirm that your \phi_{\Delta} is the same as Dirac's \phi_m?
Perhaps what is confusing me most is why my original interpretation (second post in this thread) of Dirac's weak equality is wrong. His meaning seems fairly straightforward in that passage I quoted from his text. Could you (or anyone) perhaps explain exactly what he means by saying that he rewrites the equations \phi_m=0 \longrightarrow \phi_m\approx0, since that is the entire point of this thread and I apparently am incorrect?
(Disclaimer: I'm assuming I know what's going on here)
In what Dextercioby wrote, I think he's saying that the function cΔ exists. In other words:
F \approx G \Leftrightarrow \exists c^\Delta: F - G = c^\Delta \phi_\Delta
which seems to imply that c \equiv 1
You made the freshman's mistake of dividing by zero. :smile: Recall that the proper inference from ab = a is that b = 1 or a = 0.
The point about weak equality is that you only care about what happens on a particlar set. Maybe an elementary example would help:
On the set Δ = {1}, which is defined by the constraint φΔ(x) = x - 1 (i.e. it's the solution set to φΔ(x) = 0), we have the following weak equality:
\frac{d}{dx} x^2 \approx 2
This is a weak equality because it is true at every point in Δ. It is not a strong equality because it is false on points outside of Δ.
Yet another way of looking at it is that F \approx G means that φ(P) = 0 → F(P) = G(P).
My guess: may be he just wants to point out that the total Hamiltonian contains \phi_m that are \phi_m = 0 on the constraint surface, i.e. \phi_m \approx 0. The general expression for this Hamiltonian (a Hamiltonian which is extended from the the canonical Hamiltonian on the constraint surface) has to be used to find the unphysical degrees of freedom. Well, I think I did not say anything new to the other previous posts.
Oops, I did at that... Although, I did only divide by a weak zero :)
The example did help, thanks. I think I now know where Daniel was coming from. I'm still not sure about the original question though, as to how/why Dirac used the weak inequality. This is because from your example it seems that to speak of a set of \phi_\Delta(x) as being constraints is to mean that we require \Delta=\{x:\phi_\Delta(x)=0\}...? (Now that I write this it seems awefully recursive as a definition...) So why do we say that \phi_\Delta\approx0? Does it change the definition to \Delta=\{x:\phi_\Delta(x)\approx0\}? If so, what does that mean, is it not further recursion?
Perhaps this is an irrelevant point, I don't know... It just seems to me that all the examples in this thread, whether of arbitrary or specific functions, are using weak inequalities of functions on a set of constraints - but none of them talks about what it means for the constraint equations themselves to contain weak equalities...
This is essentially what I said in my very first post in this thread, without using the language of 'constraint surfaces' - that while the functions \phi_m are required to be zero at the actual constraints, they are not everywhere zero so their derivatives may be non-zero and must therefore be evaluated in any Poisson brackets before making the substitution for \phi_m. Daniel said this was wrong, which is the only reason I am still trying to figure out what the correct interpretation is...
The constraints are just functions, so the definition is exactly the same.
φ ~ 0 means φ = 0 → φ = 0.
It's a fairly trivial statement, but sometimes the trivial can be fairly profound!
(For example, ideals are one of the most important objects of study when studying rings... but an ideal is simply the set of things that "ought" to be equal to zero, when looking at the ring from a particular perspective)
The point is, I suppose, is that it's not a "reminder" about procedure -- weak equivalence has an honest-to-goodness mathematical meaning.
When you don't make the distinction, you suffer from a sort of cognative dissonance -- sometimes you treat the objects as equal, and sometimes you don't treat the objects as equal, and that's bad because that's not how equality works.
Correct me if I am wrong.
Weak equality is used in the equations that are true ONLY when the constraints hold.
Note the word "ONLY", if weak equality had been defined in the following way without the word "ONLY"
Weak equality is used in the equations that are true when the constraints hold.
Then all strong equalities are automatically weak equalities. That's not what Dirac wanted.
Of course, the constraint function itself is zero only when the constraints hold. So \phi \approx 0
For example, if \{f, g\} = \phi
\phi is some constraint
Then we may say
\{f, g\} \approx 0
I think they are related. Computing poisson brackets involve computing partial derivatives, partial derivatives are defined assuming all variables are independent, which is only true without any contrainst.
I mean Poisson Bracket lives in the whole phase space, not only the constrained phase space.
  • · Replies 0 ·
