A question about eleastic potential energy
The discussion focuses on calculating the elastic potential energy (Ee) stored in a stretched elastic band released from a height of 95 cm, resulting in a horizontal displacement of 3.7 m. The participant determined the time of flight (t) to be 0.4403 seconds using the equation dy = v1yt + 0.5ayt², where v1 was assumed to be 0. The elastic potential energy was calculated to be approximately 19.42 J, equating to the kinetic energy (Ek) upon landing, as air resistance was considered negligible. The participant emphasized the importance of rounding the final answer to two significant figures.
  • Understanding of kinematic equations, specifically dy = v1yt + 0.5ayt²
  • Knowledge of elastic potential energy formula Ee = 0.5kx²
  • Familiarity with kinetic energy equation Ek = 0.5mv²
  • Basic principles of projectile motion and energy conservation
  • Study the derivation and application of kinematic equations in projectile motion
  • Learn about energy conservation principles in mechanical systems
  • Explore the relationship between elastic potential energy and kinetic energy in real-world applications
  • Investigate the effects of air resistance on projectile motion and energy calculations
Students studying physics, particularly those focusing on mechanics and energy conservation, as well as educators looking for practical examples of elastic potential energy calculations.
darksoulzero
A stretched elastic band of mass 0.55 g is released so that its initial velocity is horizontal, and its initial position is 95 cm above the floor. What was the elastic potential energy stored in the stretched band if, when it lands, it has a horizontal displacement of 3.7 m from the initial position under negligible air resistance?
dy=v1yt+.5ayt2
Ee=.5kx2
Ek=.5mv2
Since I knew that it would take the same amount of time for the elastic band to fall to cover the range I used the equation dy=V1yt+ 0.5ay(t)2 and rearranged it in terms of t. I got 0.4403 s. I then found vx by dividing 3.7m by 0.4403s. Since air resistance is negligible I assumed that all of the elastic potential energy, Ee, would equal the kinetic energy. I then used the equation Ek=.5mv2 and determined the Ee to be 19.41818421 J.
I didn't recheck your numbers, but how you went about solving it is correct. (I assumed you solved for t when dy = 0.95m)
Your equations are very good, but your math is off by several decimal points. Then be sure to round it off to 2 significant figures.
how do you come to 0.4403 s. if there are two unknown variables (v1 and t)?
nevermind I'm an idiot v1 = 0
  • · Replies 20 ·
