A question about QM "Observer effect"
The discussion centers on the quantum mechanics (QM) "observer effect," specifically addressing how a particle's wave function collapses upon measurement. Participants clarify that "looking" at a particle involves interaction, typically through an interaction Hamiltonian, rather than merely observing it. The wave function collapse is not universally accepted in all interpretations of QM, with alternatives like Bohmian Mechanics rejecting this concept. The conversation emphasizes that measurement outcomes depend on interactions with the system, which can lead to decoherence.
  • Understanding of quantum mechanics principles, particularly wave function behavior.
  • Familiarity with the concept of decoherence in quantum systems.
  • Knowledge of interaction Hamiltonians and their role in quantum mechanics.
  • Awareness of different interpretations of quantum mechanics, including the Copenhagen interpretation and Bohmian Mechanics.
  • Research the role of decoherence in quantum mechanics and its implications for wave function collapse.
  • Explore the differences between the Copenhagen interpretation and Bohmian Mechanics.
  • Study the mathematical formulation of interaction Hamiltonians in quantum systems.
  • Investigate measurement theory in quantum mechanics and how it relates to observable outcomes.
Quantum physicists, students of quantum mechanics, and anyone interested in the philosophical implications of measurement and observation in quantum theory.
silvercats
So if we "look" at a particle, then its wave function collapses. Does "look" mean, hitting that particle with another particle (a light particle?). A simple Yes/No answers first please. I mean, does its wave function collapse because we first need to hit that particle with an electron or a proton first, to observe it? not because it "knows" that we observe it?
It cannot be a simple Yes/No answer. The wave function collapses when you get a measurement outcome, ie. a definite result, which is an "irreversible" "classical" or "macroscopic" mark. Whether you get a definite result is up to you to decide. You can delegate it to a machine, but you have to do the delegation. This is the "observer effect" and or the "Heisenberg cut", and is part of the orthodox Copenhagen-style interpretation of QM.
However, you should also note that in that interpretation, the wave function is just a tool to calculate the probabilities of measurement outcomes.
A few comments.
First collapse isn't actually part of QM - its part of some interpretations - but others like Bohmian Mechanics don't have it. There days the modern version is how does an improper mixed state become a proper one - colloquially its why we get any outcomes at all:
http://philsci-archive.pitt.edu/5439/1/Decoherence_Essay_arXiv_version.pdf
Look does not mean that. Look means interacting with the system to produce decoherence.
Thanks
Bill
atyy said:
get a measurement
how do we "Get a measurement"?
Simpler the answer the better.
How do we INTERACT?
silvercats said:
How do we INTERACT?
Its the other way around in general - how do we not interact.
In the everyday world systems are immersed in an environment they interact with all the time - in fact that's what gives things its classical properties. For example a few stray photons from the CBMR are enough to decohere a dust particle and give it a specific location. It turns out most interactions are of the radial type so that, for example, the closer two objects get the stronger the force they feel. Mathematically they have what's called an interaction Hamiltonian.
Thanks
Bill
So am I correct If I tell that the reason for the wave function to collapse is this "interaction Hamiltonian" ?
Its a bit more subtle than that.
As I said before collapse isn't really part of QM - only part of some interpretations.
And secondly interaction (represented mathematically by the Hamiltonian) only explains what is called apparent collapse.
But, basically, with those caveats, yes.
Thanks
Bill
QM does not answer. You have to know when you get a measurement outcome.
Only a deeper theory like Bohmian Mechanics can answer such a question.
  • · Replies 24 ·
  • · Replies 42 ·
