Deepak K Kapur
- 164
- 5
Space-time is a single entity. Space does not flow.
How can time flow?
How can time flow?
The forum discussion centers on the relationship between time and space within the framework of space-time, emphasizing that while space does not flow, time is perceived to progress. Participants argue that the concept of "flow" is often misused in physics, with references to Minkowski's block universe interpretation, which posits that time does not flow as point particles exist as static lines in a four-dimensional space-time. The discussion also highlights the importance of defining terms like "flow" and understanding the invariance of space-time as a single entity, while exploring the psychological perception of time's progression versus the static nature of space.
PREREQUISITESPhysicists, philosophers of science, and students of relativity who seek to deepen their understanding of the nature of time and space, as well as those interested in the logical frameworks used in scientific discussions.
A car is a single entity. A car tire does not open and close. How can a car door open and close?Deepak K Kapur said:Space-time is a single entity. Space does not flow.
How can time flow?
How can time flow?
DaleSpam said:A car is a single entity. A car tire does not open and close. How can a car door open and close?
However, although your argument is faulty, in Minkowski's standard "block universe" interpretation time does not flow. Point particles are static lines in a 4D spacetime rather than points that move in 3D space as time flows.
pervect said:I believe it's intended to be a metaphor. Some people may perhaps take the metaphor too literally :-(.
It may be more neutral to say that time progresses, but I don't actually recall seeing anyone write that way. Common usage, for better or worse, seems to use the verb "flow" to describe the same concept as I mean when I say "progressing".
You ask why do we have a psychological feeling of flowing time and not of flowing space? It's because we remember past and not the future, which ultimately comes from the second law of thermodynamics.why does time 'progress' when space does not in our day today life.
The car is a single invariant entity also (the car is a car whether it is moving or at rest). So I don't see in what way the analogy is either a flop or misleading.Deepak K Kapur said:Actually, space-time is a single invariant entity. ( I didn’t mention it earlier because I thought it was implied).
So, your car analogy is a total flop (it’s more for misleading than informing).
Do you mean: If I construct a coordinate system where 'I' remain at the same spatial coordinates along my entire worldline, then why does the spacetime coordinates of 'me' only change in the time component, and not the spatial components? This is almost tautological...Deepak K Kapur said:why does time 'progress' when space does not in our day today life.
DaleSpam said:The car is a single invariant entity also (the car is a car whether it is moving or at rest). So I don't see in what way the analogy is either a flop or misleading.
The point is that the analogy illustrates a logical error in your original proposal. Your original proposal goes like this:
T is part of ST
S is also part of ST
S does not F
Therefore T does not F
This reasoning is clearly fallacious, as the example with the car shows. The fact that spacetime is invariant is irrelevant to the logical error you are making in the OP. You are making a simple logical error by asserting that something which applies to anyone part of a whole must also apply to each part of the whole.
I think there is some misunderstandingDaleSpam said:The question is about "flowing", not invariance.
Furthermore, your fallacious argument was not that spacetime (the whole) does not flow and therefore time (a part) can not flow. Your argument was that space (a part) does not flow and therefore time (a different part) doesn't flow. The argument you are trying to present now has a different form.
If you would like to scrap your previous argument about time flowing and make a new one then we can certainly discuss that.
Deepak K Kapur said:Can you give me an example (from physics or physical world) of a whole that consists of two parts. One part varies and the other does not. Still, the system as a whole is invariant?
No, they don't follow. Invariance and flow have nothing to do with each other. If something represents a flow in all coordinate systems then it is an invariant flow. Similarly, if a quantity represents a flow in one reference frame, but not a flow in another reference frame then it is a variant flow. Both are possible.Deepak K Kapur said:If invariance is implied, then both the questions
1. space-time (the whole) does not flow, how can time (a part) flow?
2. space (a part) does not flow, how can time (a different part) flow?
follow.
nitsuj said:What makes you think space doesn't not flow in the exact same sense as time. To your point it is a "single entity". the "flow" is c. And it applies equally to length & time.
nitsuj said:Practically speaking, length and time "flow" at c.
phinds said:It still seems to me that you are just making up your own definition of "flow". It's not a terrible one, but I've not seen it before.
nitsuj said:Sure, consider simultaneity. the distance between two points in space is dependent on the comparative motion to those points, and that distance would change as the comparative speed changes. This is the "flow". At rest with the "two points" the "flow is 100%", at near c there is much less "flow" to distance.
So "flow" here is pretty much synonymous with contraction/dilation.
Surely "flow" of time wasn't referring to an accumulation of physical happenings, ala "time-line" / aging.
DaleSpam said:No, they don't follow. Invariance and flow have nothing to do with each other. If something represents a flow in all coordinate systems then it is an invariant flow. Similarly, if a quantity represents a flow in one reference frame, but not a flow in another reference frame then it is a variant flow. Both are possible.
In my opinion, if a covariant quantity describes a flow then it would be an "invariant flow". An example would be the four-current. On the other hand, if a non-covariant quantity describes a flow then it would be a "variant flow". An example would be the standard three-current.
How can time flow?
Does the phrase "time flows" eventually come from those early water clocks?harrylin said:Related physical entities for providing the space-time data are clocks and rulers, and neither of them flows (usually).
Maybe yes!A.T. said:Does the phrase "time flows" eventually come from those early water clocks?
No, it doesn't. Invariance means that it is the same under coordinate transformations.Deepak K Kapur said:'Invariance' means 'absence of flow'. (IMHO)
