A question about the cross product as related to matrix multiplication
The discussion centers on the relationship between the cross product and matrix multiplication, emphasizing that the cross product is defined only in three dimensions. Matrix multiplication is established as a fundamental tool in mathematics, particularly for solving systems of simultaneous linear equations. Participants clarify that matrix multiplication involves the dot product of rows and columns, while the cross product is distinct and applicable in specific dimensions. The conversation highlights the practical applications of matrix multiplication in fields such as structural design and stress calculation.
  • Understanding of matrix operations, specifically matrix multiplication
  • Familiarity with vector mathematics and the concept of the dot product
  • Basic knowledge of linear algebra, particularly systems of linear equations
  • Awareness of dimensionality in mathematical contexts, especially in relation to the cross product
  • Study the properties and applications of matrix multiplication in linear algebra
  • Explore the concept of the dot product and its role in vector mathematics
  • Learn about the cross product and its geometric interpretations in three and seven dimensions
  • Investigate the use of matrices in solving systems of linear equations through practical examples
Students of mathematics, educators teaching linear algebra, engineers involved in structural design, and anyone interested in the applications of matrix operations in real-world scenarios.
RufusDawes
I understand that the cross product, in lay mans terms doesn't exist unless we're in 3 dimensions.
When you multiply two matrices together I have been told you get something similar. I hear that this is because a matrix can be treated as a vector.
So if we are talking about measurable things, in the real world does matrix multiplication have any relevance ?
I might be off the mark but what if we were to build a model, based on height weight and income would that be definable in 3 dimensions and therefore if you had two sets of observation and you multiplied them the answer would be nonsense but somehow it has a definition in 3 dimensions as a new matrix ?
if for example, i had a range of multiplies I wanted to apply to each observation or set of observations, stored in a matrix then this would be a scalar multiplication of a matrix onto another matrix ? Does such a thing exist.
Apologies I am not a mathematician so my terminology is buggered but I'm still curious.
Thanks,
Matrix multiplication is used all the time to design structures, calculate stresses, etc. It's a tool which makes doing certain mathematical calculations easier to organize and handle, especially for computers. It's like asking if regular multiplication has any relevance.
okay, so what if I were in grade 1 and didn't understand multiplication ?
Do you have some examples ? Because when I looked at some examples for vector cross product it started to make some sense. Especially when they said it only exists in 3 dimensions.
The cross product as defined for cartesian coordinates exists and has meaning for 3 dimensions and 7 dimensions.
http://en.wikipedia.org/wiki/Cross_product
The reasons for this are quite mathematically abstract.
The simplest application for matrix multiplication would probably be solving a system of simultaneous linear equations. I can't give you anything simpler than that, just like you would be hard pressed to explain multiplication to a first grader who is just learning to add. Simple matrix manipulations are usually first discussed in algebra classes in middle or high school.
http://www.mathwarehouse.com/algebra/matrix/multiply-matrix.php
Simultaneous linear equations:
http://en.wikipedia.org/wiki/System_of_linear_equations
Yes yes but no one ever actually understands what anything means, which is why you have such high drop out rates in later year mathematics courses.
For a system a linear equations it doesn't make sense, because you're multiplying a row by a column.
The multiplication of a row of a matrix times a column of another matrix (assuming the rows are the same size as the columns) does make sense. It's exactly the same as the dot product of two vectors.
$$\begin{bmatrix} x_1 & x_2 & ... & x_n\end{bmatrix} \begin{bmatrix}y_1 \\ y_2 \\ ... \\ y_n \end{bmatrix}$$
$$=x_1y_1 + x_2y_2 + ... + x_ny_n$$
Not everyone drops out. Somebody must understand some math some of the time. Otherwise we would be counting on our fingers and drooling at random intervals.
In a nutshell, that's what matrix multiplication is. The particular entry in the product matrix AB is the result of multiplying the row of A by the column of B, for all combinations of the rows and columns in AB.
I forgot about that assumption. Now it makes sense.
Matrix multiplication involves one dot product for each element in the product matrix. Matrix multiplication doesn't have anything to do with the cross product.
true, unless you form a skew symmetric matrix from a vector, which is a common way to compute cross products
  • · Replies 33 ·
  • · Replies 19 ·
