A question for the statisticians amongs us
  • Thread starter Thread starter Apteronotus
The discussion centers on the expression 0·(lim_{n → ∞} ∑_{j=0}^n Z_j) where Zj are standard normal variables. It is established that this expression is not well-defined because the sum does not converge. However, when analyzing the limit of (1/f(n))·∑_{j=0}^n Z_j with f(n) = √n, the limit diverges to a Gaussian random variable W ~ N(0,1). In contrast, using f(n) = n results in the limit approaching zero. The conversation emphasizes the importance of the choice of f(n) in determining the behavior of the limit.
Apteronotus
Suppose Zj are N(0,1).
<br /> 0\cdot \left(lim_{n \rightarrow \infty} \sum_{j=0}^n Z_j \right)<br />
Is this zero? or even defined at all?
In order to multiply two quantities, both must be individually well-defined. In your case, the quantity in the parenthesis is not well-defined, since the sum does not converge (unless you are working in some strange space where the sum actually converges...?)
Torquil
is not well-defined, but of course
lim_{n\to\infty}0\cdot \sum_{j=0}^n Z_j=0
And of course,
\lim_{n\to\infty}{\left(\frac 1{f(n)} \cdot \sum_{j=0}^n Z_j\right)}
is well-defined for f(n) = \sqrt n and for f(n) = n.
EnumaElish said:
... is well-defined for f(n) = \sqrt n ...
But if f(n)=\sqrt{n} then
<br /> lim_{n \rightarrow \infty}\frac{1}{\sqrt{n}}\sum_{j=0}^n Z_j<br /> =lim_{n \rightarrow \infty}\frac{\sqrt{n}}{n}\sum_{j=0}^n Z_j<br /> =\left(lim_{n \rightarrow \infty}\sqrt{n}\right) \cdot \left(lim_{n \rightarrow \infty}\frac{1}{n}\sum_{j=0}^n Z_j\right)<br /> =\left(lim_{n \rightarrow \infty}\sqrt{n}\right) \cdot \mu<br />
by law of large numbers, where \mu is the mean of the Z's. And consequently the limit diverges!
Yes, that is as expected. E.g. the mean for finite n is \mu\sqrt{n}, so this cannot converge.
This is unrelated to the expression of the Wiener process as a limit of finite-time difference increments, since in that case \mu=0 and therefore you cannot split the limit expression in the same way since you would then get "\infty\times 0".
Torquil
So
1. why/how is the expression <br /> \lim_{n\to\infty}{\left(\frac 1{f(n)} \cdot \sum_{j=0}^n Z_j\right)}<br />
well defined for f(n)=sqrt n as EnumaElish stated above?
and
2. what is its value?
Apteronotus said:
So
and
Assume that Exp[Z] = 0 and Var[Z] = 1, for all the Z's.
If you use f(n) = n then you get zero in the limit. You can prove this using the law of large numbers, as you did for one of the parenthesis you had above (just put your \mu=0).
If f(n) = sqrt(n), the limit is not a single number, but a gaussian random variable W ~ N(0,1). Notice that for each finite n, the expectations and variance of the truncated sum W_n is:
Exp[W_n] = 0, Var[W_n] = 1
This is true for finite n, and independent of n, so it is also true in the limit.
