A question on elasticity from Kittel's Solid State Physics book
The discussion revolves around an equation related to elastic energy density from Kittel's "Introduction to Solid State Physics." Participants seek clarification on the equation's derivation and the roles of the constants and variables involved, particularly in the context of elasticity theory.
  • One participant expresses confusion about the equation for elastic energy density, specifically regarding the constants \(C_{\lambda\mu}\) and strains \(e_{\lambda}\).
  • Another participant notes that \(C_{\lambda\mu}\) are elastic moduli (constants) while \(e_i\) are strains (not constants), likening the equation to spring energy.
  • A participant questions the assumption that the derivatives of \(C\) and \(e\) should be zero, citing the use of coefficients in the text.
  • Another participant asks for clarification on what the derivative is taken with respect to, asserting that the derivative of strain need not be zero.
  • One participant mentions that Kittel's motivation for discussing waves in cubic crystals is not particularly insightful.
  • A participant provides a mathematical perspective, suggesting that the energy expression is expanded in terms of six degrees of freedom to the second order, with the constant coefficient tensor emerging from the derivative of free energy.
Participants express differing views on the interpretation of the constants and variables in the equation, and there is no consensus on the implications of derivatives in this context. The discussion remains unresolved regarding the clarity of Kittel's derivation.
Some participants note the potential for confusion regarding the definitions and roles of constants and variables in the equation, as well as the assumptions underlying the derivation.
hagopbul
TL;DR
reviewing the introduction to solid state physics by charles kettle and in the 3ed chapter there is this equation that is little unclear
Hello All :
i am reviewing charlse kettle book introduction to solid state physics and came across an equation in the 3ed chapter which is a bit unclear
hope that physics forums members can clear it more if that possible
the equation 1st mentioned in the 3ed chapter page number 84
it is about the elastic energy density U :
##U =(1/2)\sum_{\lambda=1}^{6}\sum_{\mu=1}^{6}[C_{\lambda\mu}e_{\lambda}e_{\mu}]##
then the writer start deriving the above equation which i didnt understand , could any one explain it especially that the above equation is consist of constants (c,e)?
Best
Hagop
hagopbul said:
TL;DR Summary: reviewing the introduction to solid state physics by charles kettle and in the 3ed chapter there is this equation that is little unclear
Hello All :
Best
Hagop
Cλμ are the elastic moduli (constants)
ei are strains (not constants)
it is essentially the spring energy (½kx2) for elastic materials
thanks but if they are constant shouldnt the derivative of C and e be = 0 in the book e also constant
you will read in the above pages coefficients
" it is usual to work with coefficients e rather than epsilon"
the writer give the impression that he get e from deriving a 1st degree equation
I do not have Kittel in front of me. So I am responding blind.
Derivative with respect to what?
There is no reason for the derivative of strain to be zero.
Cij is commonly a constant. I believe the equation you wrote requires it to be, but I might be wrong.
tomorrow i will take a screenshot of the pages and paste them here excuse me in is near 2 am here
I took a look at Kittel. He is trying to motivate waves in cubic crystals. I do not think it is a particularly insightful motivation.
It is Kittel and not Kettle. (Unless Ma and Pa Kettle wrote a textbook)
I've changed the title.
My two cents, mathematically, it's basically an energy expression expanded in terms of six degree of freedoms to the 2nd order of geometry changes (those e_i). Since the solid is stable, thus 1st term vanishes, only the quadratic term is left. The derivative of (free) energy w.r.t geometry changes renders the constant coefficient tensor. One can then write in the compact fancy form of repeated summation over 6 indices.
I do not believe that Kittle is better than Kettel. :wink:
  • Haha
Hah! Touché. Title changed again. Or is it titel? :wink:
thanks for changing the title it was 2 am , and going to post the pages in few hours
10K
