A sphere held steady on a slope by a rope
  • Thread starter Thread starter Theexploer
    Rope Slope Sphere
The discussion revolves around a physics problem involving a sphere held steady on a slope by a rope. The problem includes calculating the forces acting on the sphere and determining the radius of a circle related to its motion on an inclined plane.
  • Mixed
  • Participants discuss the equilibrium of forces acting on the sphere, with some attempting to derive equations based on the angles involved. Others express confusion regarding the clarity of the provided diagram and the definitions of various symbols used in the problem.
Some participants have offered insights into the relationships between the forces and angles, while others are questioning the adequacy of the provided drawing and the clarity of the problem statement. There appears to be an ongoing exploration of the necessary calculations and the assumptions made in the problem setup.
Participants note that friction is non-existent and that the problem involves specific angles and dimensions, which may not be fully represented in the drawing. There is a mention of missing information regarding the symbols used in the equations.
Theexploer
- Calculate the intensities of the forces applied to the sphere. Choose the cOy coordinate system shown in the diagram.
- Calculate the radius of the sphere.
friction is non-existent.
A sphere of mass m = 150g of radius r = O'C = O'A is held in equilibrium on a perfectly smooth inclined plane by a wire AB of length l = 0.25m.
The angle between the inclined plane and the horizontal is a = 10*.
The angle between the inclined plane and the wire AB is Beta = 20*.
The sum of the forces should be 0.
Sin A'C'B' = px/b
px = mg . sin alpha
P should be px = - m.g. sin alpha and py = m.g.cos alpha
Finally i fund as result F = -0.8 and R = -1.23
but for the second question i didn't fund the radius of the circle.
I think you need a better drawing. The one you show is deceptive in that it shows that the string is horizontal which would make ##\beta=\alpha## whilst it is given that ##\beta=2\alpha.## A drawing (more or less) to scale would be easier to analyze.
Unfortunately that's the only drawing I got on the book.
Drawing, however poor, is probably enough.
Getting R requires a demonstration that O' - A - B lie on a straight line (as drawn, but how do you prove that?), and then it's just algebra with quantities that are known.
The forces involved are irrelevant to the computation of radius.
But the question asks for the intensities of the forces applied to the sphere which i'm not sure about my results, and to calculate by the given written informations find the radius of the cirlcle that's what i'm looking for.
Theexploer said:
Homework Statement: - Calculate the intensities of the forces applied to the sphere. Choose the cOy coordinate system shown in the diagram.
Relevant Equations: A sphere of mass m = 150g of radius r = O'C = O'A is held in equilibrium on a perfectly smooth inclined plane by a wire AB of length l = 0.25m.
Sin A'C'B' = px/b
px = mg . sin alpha
Hello again :smile: ,
Like in your other thread I am misssing things. What do the various symbols represent ? ## px, \ py,\ P, \ b, \ ? ## (I suspect ##P = p = m\vec g \ ## (correct ?)
No idea if, similarly, ##A = A'## etc. Why confuse everybody ?
Theexploer said:
Sin A'C'B' = px/b
Do you mean ##\sin(\angle \text {ABC})## ?
With ##\vec p_x = mg\sin\alpha ## you have the x component (along the incline) of the weight . It is compensated by the x-component of the pulling force ##\vec T##
It took me a while to come up with this drawing.... (read ##mg\cos\alpha## instead of ##mg\operatorname{scos}\alpha## :wink: )
Easy to see ##\sin \beta = R/(AB + R)## -- no physics for part 1.
For part 2 you have ## mg\sin\alpha = T \cos\beta## with ##T## the tension from the rope.
Three forces act on the sphere: ##mg, T ## and the normal force ##N## . Done :smile: .
That's not an argument. If I can draw this, so can you !
Thank you very much for this detailed explanation
  • · Replies 97 ·
  • · Replies 20 ·
15K
