About pair production using light
The discussion centers around the concept of pair production using light, specifically whether a single photon can create multiple pairs of particles, such as electron-positron pairs. Participants explore the theoretical implications, conservation laws, and the conditions under which pair production occurs, including the role of additional particles like atoms or photons.
  • Some participants inquire whether light can create two pairs of particles, specifically electron-positron pairs, if sufficient energy is provided.
  • There is a suggestion that only one pair can be created by one photon, with references to conservation of energy and charge.
  • Some participants argue that pair production can occur in the presence of an atom or molecule to balance momentum, but the exact reasons for the limitation on the number of pairs produced remain unclear.
  • Others clarify that pair production is a process involving photons, and higher-order processes may allow for multiple pairs from multiple photons, but this is considered less likely.
  • One participant proposes a hypothetical scenario involving the decay of a neutral pion into photons and then into multiple electron-positron pairs, suggesting that conservation laws are not violated in such a case.
Participants express differing views on the possibility of creating multiple pairs from a single photon, with some asserting limitations while others propose hypothetical scenarios. The discussion remains unresolved regarding the exact conditions and processes involved in pair production.
Participants reference conservation laws and the role of additional particles in pair production, but the discussion includes uncertainties about the mechanisms and conditions required for producing multiple pairs.
wasong
TL;DR
Can light make two pairs? (assuming enough energy to make two pairs)
If so, why?
If so, why? or If not, why not?
Welcome to PF.
Two pairs of what?
Baluncore said:
Welcome to PF.
Two pairs of what?
Thank you~ (electron+electron+positron+positron)!
Whence these pairs?
PeroK said:
Whence these pairs?
I don't understand. What's mean "Whence"?
PeroK said:
Whence: from what place, source or cause.
https://www.merriam-webster.com/dictionary/whence
in a book: Electromagnetic waves (with enough energy) = γe− + e+
in my opinion: Electromagnetic waves (with enough energy) = γe− + e+ that's right! or Electromagnetic waves (with enough energy) = γe− + e− + e+ + e+ also that's right! because There's no problem if you keep Conservation of energy and conservation of charge.
wasong said:
in a book
That is NOT a proper citation on this forum. You might as well say "some guy on a bus told me".
Sorry.. The book is Concepts of Modern Physics. I was not good at English and citation.
This pair production can only take place in the presence of an atom of molecule - which is required to balance momentum. I don't know why precisely only one pair may be produced - I'm sure someone will answer that - but it's not enough just to say that energy and momentum are conserved. There must be a possible interaction between the photon and the atom that produces two pairs.
You probably mean "photon," not electromagnetic waves. Pair production is one of the basic processes in QED, and it's actually ##\gamma + \gamma \to e^- + e^+##. There are probably higher-order processes which can produce multiple electron-positron pairs from a single pair of photons, but it's much less likely to occur. And, of course, if you start with multiple pairs of photons, each could produce an electron-positron pair.
Does the word "less likely" mean that there is a possibility of it happening? from a single pair of photons
If the answer to my question is yes, where can I find the relevant concept or data?
This is a different process: this is pair production from a pair of photons. It's the reverse of pair annhililation.
An electron-positron pair can annhililate and produce an even number of photons; but, I'm not sure that two photons could produce more than one electron-positron pair. I suspect that you can only get one electron-positron pair per pair of photons.
And similarly in the case of pair production from a single photon where the interaction involves additionally an atom or molecule.
It's essentially the same process. It's just that in the case involving a nucleus, the second photon is a virtual photon from the interaction of the photon with the nucleus.
An electron-positron pair can annihilate and produce an even number of photons; but, I'm not sure that two photons could produce more than one electron-positron pair. I suspect that you can only get one electron-positron pair per pair of photons.
It's been a long time since I studied particle physics, but I'll say I think it's possible though I'd expect it to be really unlikely. For example, the neutral pion can decay into two photons, and it can also decay into two electron-positron pairs. So conceivably, two photons could produce a pion, which is simply the reverse of the first decay I mentioned, that then decays into two electrons and two positrons. At the least, this hypothetical scenario suggests no conservation laws are broken which would invalidate the process of two photons producing two pairs.
The simplest scenario which might work is two photons coupling to separate electron-positron pairs and then then one particle from one pair exchanges a virtual photon with a particle from the second pair so that momentum and energy are conserved.
  • · Replies 0 ·
