Abraham's light momentum breaks special relativity?
153 replies · 29K views · last reply
sciencewatch
The Abraham's photon moment p_A=hbar*w/n*c is not Lorentz covariant, but it has been confirmed by several experiments. For example, G. B. Walker and D.G. Lahoz, Nature 253, 339 (1975); W. She, J. Yu, and R. Feng, Phys. Rev. Lett. 101, 243601 (2008).
The special relativity is flawed or the experiments were not correctly observed?
You lose me here?
"An equation is said to be Lorentz covariant if it can be written in terms of Lorentz covariant quantities (confusingly, some use the term invariant here). The key property of such equations is that if they hold in one inertial frame, then they hold in any inertial frame (this follows from the result that if all the components of a tensor vanish in one frame, they vanish in every frame).
This condition is a requirement according to the principle of relativity, i.e. all non-gravitational laws must make the same predictions for identical experiments taking place at the same spacetime event in two different inertial frames of reference."
Are you saying that the Abraham effect, in where the photon is seen to lose momentum entering a medium is inconsistent? It's been tested and seems to be correct, as far as I know? If you are referring to the way, if seen as a wave, the 'momentum' increase, as the wavelength is found to decrease, then that is correct too. The problem only exist if you want radiation to be only' one', or the other.
Or, is it something else you mean?
yoron said:
You lose me here?...Or, is it something else you mean?
Let me re-state my question.
For a plane wave in an isotropic, homogeneous, non-conducting medium, the wave vector k and the frequency w constitute a wave 4-vector (k,w/c) which is Lorentz covariant, where |k|=n*w/c with n the refractive index. Sine the Planck constant hbar is assumed to be a Lorentz invariant. Thus hbar*(k,w/c) is a Lorentz covariant momentum-energy 4-vector. The Minkowski's photon momentum is defined as p_M=n*hbar*w/c = hbar*|k|, and we say the Minkowski's momentum hbar*k is Lorentz covariant, as the space component of hbar*(k,w/c).
However, the Abraham's momentum p_A=hbar*w/(n*c) does not have such property, that is, it is not Lorentz covariant, unless in free space. But some experiments strongly support Abraham's formulation. Is the special relativity flawed? or the experiments were not correctly observed?
DaleSpam said:
Here is a good review article on the topic.
http://arxiv.org/abs/0710.0461
This is a good review paper.
It is mainly talking about various EM and material tensors which are used to obtain various momentum and energy conservation equations.
In principle, Maxwell equations support various momentum conservation equations; however, this is an indeterminacy. It is the indeterminacy that results in the question of light momentum in a medium.
Yes, and the answer doesn't really matter. What matters is that the total energy and momentum is conserved and covariant. You can break that total momentum up into parts which are not covariant, but that does not challenge SR in any way.
"You can break that total momentum up into parts which are not covariant, but that does not challenge SR in any way."
Do you have any theoretical grounds that support "partial momentum" is not Lorentz covariant?
No, I was just going by your claim in the OP that it is not covariant. Do you have reason to doubt your own claim? I do not.
1. "by your claim in the OP that it is not covariant" --- What does it mean for "OP"?
2. My reason is:
Sine the Planck constant hbar is assumed to be a Lorentz invariant. Thus hbar*(k,w/c) is a Lorentz covariant momentum-energy 4-vector. Because hbar*w/c is the photon's energy, hbar*k must be the photon's momentum according to the relativity covariance. Thus only the Minkowski's photon momentum is consistent with the relativity, while the Abraham's momentum is not.
OP = Original Post or sometimes Original Poster
sciencewatch said:
2. My reason is:
Yes. And since the choice between them is arbitrary I would recommend using Minkowski's momentum if you are doing relativistic problems.
However some experts of relativistic electrodynamics insist that the wave 4-vector be Lorentz covariant, but the light momentum may take Abraham's momentum. Does that mean the special relativity has some flaw? For example, see: T. Ramos, G. F. Rubilar, and Y. N. Obukhov, Phys. Lett. A 375, 1703 (2011), http://arxiv.org/abs/1103.1654 .
Not at all. A similar thing happens with gauges. There are many different possible choices for gauges. For example Coulomb or Lorentz. Both are equally valid but the Coulomb gauge is not covariant. No big deal.
There also have experiments with a high credibility to support Minkowski momentum,e.g.
Campbell, G.K., Leanhardt, A.E., Mun, J., et al, "Photon Recoil Momentum in Dispersive Media", Physical Review Letters. Vol94, issue 17, 2005, pp.170403
Wang Zhong-Yue, Wang Pin-Yu, Xu Yan-Rong (2011). "Crucial experiment to resolve Abraham-Minkowski Controversy". Optik 122 (22): 1994–1996.
Choice of gauges and choice of light momentum formulations are different things.
Gauge is a kind of math tool, while light momentum is a physical reality.
Without using Lorentz gauge or Coulomb gauge, one still can solve EM problems. The solutions to Maxwell equations do not deppend on the choice of gauges.
Without Lorentz gauge, covariant EM-field strength tensors also can be set up.
Light momentum is a measuable physical quantity; theoretically there should be a correct formula to calculate, in my opinion. If both Abraham's and Minkowski's formulas are correct, then n=1 must hold.
Minkowski's momentum is Lorentz covariant, and it is supported by the Fizeau running experiment.
Sometimes, I wonder if special relativity is even compatible with itself. If you take d'/t', you don't get v. They are inversely related to the lorentz, so you would then get a different velocity than the original that determined the amount of spacetime dilation in the first place. I vote for a misassigned t' variable.
In special relativity (or rather in the MInkowski space-time of Special relativity), v always equals dx/dt, so I don't know what your problem is. Offhand, I'd guess you were, in fact, using a missagned 't' variable from the wrong frame, not realizing or having some sort of mental block about 't' being frame dependent.
Note that this remark doesn't apply to GR, because in GR coordinates are general and don't necessarily directly represent distances (or times). This is somewhat similar to the way that lattitude and longitude on the Earth's surface are coordinates, and don't represent distances until you apply the metric.
If you look at a geometrical view of SR, there is no reason why velocity shouldn't equal d'/t', since it would equal c. You can pythagreom theorom the equation for t' and d', but then you can't get the original value back that you tried to solve to correct getting the constant value c. d'/t' doesn't give you back c like it should. It would be similair to checking your answer that c is indead the same, the goal of assigining d' and t' in the first place.
If t'=t sqr(1-v^2/c^2), and L' = L sqr(1-v^2/c^2), then the lorentz portion would cancel and then L'/t' = c. The difference between the time dilation equation is exchanging the time variables, t and t'. The way it is L'/t' does not equal c.
SR has only been around for a hundred years, geometry and algebra was tried and tested for thousands...
Why would you think that? Did you not read the article I referenced earlier? The light momentum is not a physical reality, only the total momentum is. How you partition that into light and matter momentum is arbitrary, not physical.
I can give a long list of quantities that can be measured which depend on some arbitrary choice.
Position
Velocity
Energy
Momentum
Time
Direction
Potential
Length
Duration
Net force
Etc.
Abraham's and Minkowski's photon momentums all mean single photon's momentum, instead of the total momentum: light plus material .
I read that paper, which is talking about how to construct various total EM stress-energy tensors based on field- and material-tensors. In principle, one can construct infinite kinds of such tensors, resulting in infinite momentum-conservation equations, just like the Poynting power density vector S=ExH: actually adding an arbitrary vector A with div(A)=0 to ExH will not violate Poynting theorem, namely div (ExH+A)=div (ExH)= ... That is why I say Maxwell equations support variuos light momentum conservation equations.
Position
Velocity
Energy
Momentum
Time
Direction
Potential
Length
Duration
Net force
Etc.
I think you got misunderstanding of what I mean. Those quantities you mentioned can be described by Newton's law in classical mechanics.
Exactly. The choice between them being arbitrary.
It's interesting.
http://physicsworld.com/cws/article/news/41873
Yes. So I think Minkowski momentum is reasonable and Abraham is incorrect.
yoron said:
It's interesting.
"A century has now passed since the origins of the Abraham-Minkowski controversy pertaining to the correct form of optical momentum in media. Since, the debate has been recast in terms of the wave-particle duality of a photon..."
See: B. A. Kemp, J. Appl. Phys. 109, 111101 (2011).
Then there is a pool of light momentum formulations; take one that can fit your own experiment...
if the special relativity holds for light momentum.
In the photon-medium block argument for Abraham's light momentum, the photon's mass is taken to be hbar*w/c**2, and the photon's speed is taken to be c/n; thus from Newton's law, momentum=mass*veclocity ----> p_A=(hbar*w/c**2)*(c/n)=hbar*w/n*c.
See: U. Leonhardt, Nature 444, 823 (2006).
http://lib.semi.ac.cn:8080/tsh/dzzy/wsqk/Nature/vol444/444-823.pdf
For the photon, mass-energy equivalence: mass=energy/c**2=hbar*w/c**2 really has nothing open to question?
