Absolute value removed from equation. Why?
The discussion revolves around the implications of the absolute value inequality \(\left | x_{n} -L\right |< \epsilon\) and its relationship to the expression \(x_{n} > L-\epsilon\) given that \(\epsilon > 0\). Participants explore the properties of absolute values in the context of sequences and limits.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Some participants suggest trying examples to understand the implications of the absolute value. Others discuss splitting the problem into cases based on the sign of \(x_{n} - L\). There are questions about whether one can exclude cases based on the nature of the sequence \(x_{n}\). Participants also explore the mathematical definitions of absolute values and their application to the problem.
The discussion is active, with participants providing insights and clarifications on the implications of the absolute value inequality. Some guidance has been offered regarding the rewriting of the inequality and the consideration of cases, though there is no explicit consensus on the interpretation of the problem.
Participants note that the behavior of \(x_{n}\) can vary, as it may be positive or negative depending on the series it belongs to, which complicates the application of the absolute value definition. There is also mention of the importance of considering all cases in a proof.
jens.w
Given that [itex]\epsilon[/itex]> 0, why is it, that [itex]\left | x_{n} -L\right |< \epsilon[/itex] implicates that [itex]x_{n} > L-\epsilon[/itex] ?
Try some examples to get a feel for it.
Since you're dealing with absolute values, you could always use the usual technique for dealing with them: split into two cases depending on whether the argument is positive or negative.
Well if: l Xn-L l ≥0 then you can remove the the absolute value.
No, you can't. We have |-2| > 0; would you say that -2 > 0? Besides, for ANY real number r we always have |r| ≥ 0.
RGV
Remember that an equation like ##|x_n-L|<\epsilon## can always be rewritten ##-\epsilon < x_n-L < \epsilon##. Add ##L## to all three sides and notice you are only using half of the result.
Yes, i thought of that at first, but it doesn't help in this case since [itex]x_{n}-L[/itex] can be either positive or negative at all points, or alternating, depending on what series [itex]x_{n}[/itex] is a part of. So based on that, i can't exclude one of the cases via the definition.
If x >= L then x > L-ε (ε>0). So, just look at the case where x < L (assuming |x-L| < ε).
RGV
As I am sure you know, |x|= x if [itex]x\ge 0[/itex], and |x|= -x if x< 0. So if [itex]x_n- L< 0[/itex], then [itex]|x_n- L|= -(x_n- L)= L- x_n< \epsilon[/itex] so that [itex]-x_n< -L+ \epsilon[/itex] and, multiplying boty sides by -1, [itex]x_n> L- \epsilon[/itex]. Of course, if [itex]x_n- L\ge 0[/itex] then [itex]x_n\ge L[/itex] and, since [itex]\epsilon> 0[/itex], [itex]L> L- \epsilon[/itex] so [itex]x_n> L-\epsilon[/itex].
In either case, [itex]x_n> L- \epsilon[/itex].
It doesn't matter that xn comes from a series; the question you asked is one about the property of the number xn.
And besides, in a proof by cases you don't exclude a cases: you consider all of them. (in this case, only 2)
RGV
Yea that makes sense.
That also makes sense! And how creative too.
Your right, i was confused.
I guess the problem i had (besides being stupid of course) is that i got hung up on the results from the definition. They seemed to conflict and give 2 different cases, but that wasnt the case, which i feel that HallsOfIvy showed me.
Thank you all.
  • · Replies 26 ·
  • · Replies 32 ·
