Absorption of an Exciton and Exciton propagation
  • Context: Graduate
  • Thread starter Thread starter Sciencestd
    Absorption Propagation
The discussion focuses on the absorption spectrum of TIPS Pentracene in different environments, specifically comparing its behavior in toluene versus in an aggregate or layer form. It is established that the absorption spectrum varies based on the surrounding medium, making it impossible to predict the spectrum for a layer of TIPS Pentracene without experimental data. Additionally, exciting TIPS Pentracene with a wavelength between two maxima in its absorption spectrum will likely inhibit exciton propagation due to insufficient energy for movement.
  • Understanding of exciton dynamics in organic materials
  • Knowledge of absorption spectroscopy principles
  • Familiarity with TIPS Pentracene properties
  • Basic concepts of solvent effects on material properties
  • Research the experimental methods for measuring absorption spectra of organic semiconductors
  • Study the effects of solvent on the optical properties of TIPS Pentracene
  • Learn about exciton propagation mechanisms in layered materials
  • Investigate the role of excitation wavelengths in exciton behavior
Researchers in organic electronics, materials scientists, and anyone studying exciton dynamics in organic semiconductors will benefit from this discussion.
Sciencestd
I read articles talk about the absorption of the exciton in a solvent, such as TIPS Pentracene in toluene. My question is does the absorption spectrum keep the same for aggregate TIPS Pentracene , in case if I want to know for a layer of TIPS Pentracene?!
My second question is: let's say I know absorption spectrum of Exciton, such as TIPS Pentracene, and I excite it with wavelength between two maxima in the absorption spectrum (not necessary that is minimum but a region between two maxima)... does then exciton propagation occurs?
The absorption spectra of a material depends on the environment it is in, so the absorption spectrum of TIPS Pentracene in toluene may be different than that of an aggregate or a layer. Therefore, it is not possible to determine the exact absorption spectrum for a layer of TIPS Pentracene without performing an experiment.When you excite a material with a wavelength between two maxima in the absorption spectrum, the exciton will likely not propagate. This is because the energy of the excitation will be too low for the exciton to move.
  • · Replies 16 ·
