Arfur Bryant
- Messages
- 23
- Reaction score
- 0
AlephZero said:You need to take everything in your scenario into account here. If the fire is in a closed room (whatever the size of the room) it will be absorbing the heat radiated back from the walls of the room. Adding a chair into the scenario is just a detail.
Suppose the electrical power into the fire is a constant 1000W.
If the fire was in outer space (and ignoring the existence of the rest of the universe) it would reach a constant temperature where it radiated 1000W, the same as the electrical power.
If it was in a room where its surroundings radiatie say 10W of heat back to the fire, it will be at a slightly higher constant temperature where it radiates 1010W. The net amount of heat entering the room is still 1000W.
Of course there must be some way for the net 1000W of heat to get out of the "closed" room (e.g. conduction through the walls and convection into the air outside), otherwise the fire and the room will never reach a constant temperature. They will both increase in temperature "for ever" (at least, until something melted or caught fire), because of the 1000W of electrical heat input.
AlephZero,
I understand what you are saying. However, are you really sure that the filament of the fire gets hotter? That was my question. Because, if it does, then it appears to me that the 2nd Law of Thermodynamics has been broken. Remember that the only thermal energy in the room comes from the filament. If it truly absorbs the 10W from the walls, then the filament has heated itself. How can something heat itself?
The chair is not to be dismissed. Adding the chair provides an example of a cooler body in addition to the walls which had been at equilibrium with the fire (as I stated). My question addresses whether the 'backradiation' from the chair can heat the filament. Do you agree with this?
However, thank you for a comprehensive reply.
AB
