Abstract Algebra Mod 6 Subgroup Computation and Generator Identification
20 replies · 4K views · last reply
kathrynag
I'm working with a mod 6 addition table.
I want to compute the subgroups <0>,<1>,<2>,<3>,<4>,<5>
I also want to find what elements are generators of the group mod 6.
Then I wnat to use do a subgroup diagram.
I am not sure about how to compute sungroups. Doe sthis incolve something like:
1+1+1 and so on?
I know an element is a generator if <a>=G. My problem is figuring out which elelments are. Is it when 2 subgroups are equal?
Ok, is there a general way to determine a subgroup from a table. I think if I can figure out one, I'll be fine on the rest.
1+1+1 and so on?
Yes. And when you start getting repeat elements, you're done.
Just do it! Work out all 6 cyclic subgroups then it will be obvious when two of them are equal.
What do you mean by repeat elements. So I for
<0> =0+0=0+0=0
<1>=1+1=2+1=3+1=4+1=5+1=0+1=1+1=2=<2,3,4,5,0>
<2>=2+2=4+2=0+2=2+2=4=<4,0,2>
<3>=3+3=0+3=0
<4>=4+4=2+4=0+4=4+4=2=<2,0,4>
<5>=5+5=4+5=3+5=2+5=1+5=0+5=5+5=4=<4,3,2,1,0>
So,<<0> and <3> are generators. Is what I did correct?
I mean that when the elements start to repeat, then stop.
<0> =0+0=0+0=0
So for this one, [itex]<0>=\{0\}[/itex]. There's nothing more you can get out of it.
Your notation is very sloppy. You can't just set all of those things equal to each other like that. You've got 1+1=2+1, which is obviously not true. Plus you didn't take it far enough. 1 should be in that subgroup too. Also you shouldn't list the elements of a subgroup in angled brackets. You should use curly braces instead. So in this case, [itex]<1>=\{0,1,2,3,4,5\}[/itex].
<3>=3+3=0+3=0
Bad notation aside, you got the subgroups [itex]<2>[/itex] and [itex]<4>[/itex] correct. You didn't take [itex]<5>[/itex] far enough, and I can't tell if you know what you're doing on [itex]<3>[/itex] because you didn't write your answer down.
No, neither of those are generators. I suggest you look up the definition of "generator of a group".
Ok, so I want to make sure, I have every possible number in the subgroup.
<5>=5+5=4+5=3+5=265=1+5=0+5=5+5=4
<5>=<4,3,2,1,0,5>
<3>=3+3=0+3=3+3=0
<3>=<0,3>
An element a of a group G generates G and is a generator for G if <a>=G.
Something about the definition doesn't make sense.
My thought is that <1>, <5>, <2>, and <4> are generators because they have the same elements.
You really must stop doing this. "5+5=4+5" is simply not true.
<5>=<4,3,2,1,0,5>
Yes, but you should use the curly braces as I said. What you've written here means something else. The notation [itex]<a,b>[/itex] means "the group generated by a and b", not "the set whose elements are a and b."
<3>=3+3=0+3=3+3=0
<3>=<0,3>
Bad notation aside, this is correct.
It makes perfect sense. Either [itex]<a>=G[/itex] or it doesn't. There's no ambiguity, so it's a fine definition.
Now that doesn't make sense. [itex]<1>[/itex] isn't a generator, it's a subgroup. The fact that [itex]<1>=G[/itex] means that 1 is a generator. 5 is also a generator, but 2 and 4 are not. Do you see why, in light of the definition of "generator"?
Ok, I think I know where my confusion is I understand <a> is a subgroup, but I don't understand what the group G is.
Oh, so G consists of the elements 0,1,2,3,4,5 and <1> and <5> have all these elements, so they are generators?
Yes, that's right.
More precisely, <1> and <5> have all these elements, so 1 and 5 are generators. A generator is an element of a group, not a group itself.
Ok, that makes sense. I have to make an addition table of these subgroubs.
Ok, so <1>+<2>= ?
I'm not sure what to do when the sizes of the groups aren't the same?
Would <2> +<4>=<0>
<1>+<2> doesn't make any sense. You don't add subgroups, you add elements. What exactly were you asked to do?
Give the subgroup diagram for the subgroups of mod 6.
I thought this menat creating an addition table.
No, it doesn't mean that. Isn't there an example of such a thing in your book?
Not really:
My book doesn't explain very well.
i think I start with 1 and create a diagram connecting with 2, 3, 4, 5, 0?
That's the book I learned from. It explains subgroup diagrams with examples.
Ok, so I think I have an idea the subgroup <0> stems out from <3>
Ok, I think I'll get it eventually. It's just a different way of thinking.
At the top should be the full group. Then below that you put its largest subgroups and connect them with a line segment. Continue mapping out the heirarchy of subgroups until you arrive at [itex]<0>[/itex] at the bottom. So yes, [itex]<0>[/itex] and [itex]<3>[/itex] are connected. But that's not the only subgroup [itex]<0>[/itex] is connected to.
