Abstract math prove involwing sets
4 replies · 3K views · last reply
beatka6
Let Ts denote the set of points in the x; y plane lying on the square whose
vertices are (-s; s), (s; s), (s;-s), (-s;-s), but not interior to the square. For
example, T1 consists of the vertices (-1; 1), (1; 1), (1;-1), (-1;-1) and the
four line segments joining them. Let
S = union of Ts, where s is an element of positive real numbers
Determine a set J, that is not de ned in terms of unions, that equals S. Prove
that S and J are equal.
Please help. I have no idea how to start that problem. What I figure out is that J=AuBuCuD, where set A={ (x,y)| (x,y)=(s,y), for -s≤y≤s} B={(x,y)| (x,y)=(-s,y), for -s≤y≤s}, C={(x,y)| (x,y)=(x,s), for -s≤x≤s}, D={(x,y)| (x,y)=(x,-s), for -s≤x≤s}
I do not know how to write down set S in different form and how to prove that J=S
Try explaining in words what points of the plane are contained in [itex]\cup T_s[/itex]. Alternatively, it might be easier to identify what points are NOT contained in the union.
here are a couple of hints:
suppose (x,y) lies on some square Ts. if (x,y) is in the 4th quadrant, then (x,-y) is in the 1st quadrant, on the same square Ts. if (x,y) is in the 3rd quadrant, then
(-x,-y) is on the same square in the first quadrant, if (x,y) is in the 2nd quadrant, then (-x,y) is in the 1st quadrant.
so you may as well just consider (x,y) in the first quadrant, from symmetry considerations.
now show that if x = y, (x,y) is the corner of some square (which one?), if x > y, (x,y) is on the right vertical side of some square (again: which one, that is...what is s?), and if y < x, then (x,y) is on the top edge of some square (and s is...?).
of course, not every point of the plane is in a quadrant. some points lie on the x-axis, and some points lie on the y-axis. consider these points separately.
last hint: is a square with sides of length 0 allowed?
So in my set s cannot equal -s. Would that take care of the problem with 0 side length? But in that problem it does not say that it can't but it says that s is a positive real number, so 0 it is not included because 0 is not negative nor positive.
you are correct that 0 is not a positive real number.
