AC Power and Combining Volt/Current
The discussion revolves around the use of AC power versus DC power, specifically focusing on how to combine multiple 220V lines to achieve a higher voltage for an appliance that requires 660V. The original poster presents a scenario involving three 220V wires and questions how to utilize them effectively without exceeding the maximum voltage of the wires.
  • Participants explore the concept of combining voltages from multiple wires and question the feasibility of using a single return wire. There are discussions about the maximum voltage and current ratings of the wires, as well as the implications of phase differences in a three-wire system.
The conversation is ongoing, with participants raising questions about the original poster's assumptions and clarifications provided by a teacher. Some participants suggest that the return line may not carry current under ideal conditions, while others express confusion about the relationship between voltage and current in the circuit setup.
There are mentions of potential misunderstandings regarding voltage levels in AC systems, specifically the maximum voltage differences between phases and the implications of using a three-phase supply. The original poster's scenario includes constraints such as the maximum current capacity of the wires and the need for clarification on circuit behavior.
elink24
One of the reasons we use AC power instead of DC is that with AC, we can use a single wire with a maximum voltage of 220V to return 660V. This is done by combining 3 lines of 220V into a single one. How can this be done without exceeding the wire's max voltage of 220V?
My teacher also added this to clarify, "Ha, I realized that I was thinking in European terms, where they use 220V. Anyway, suppose I have an appliance (like an AC) that needs 660V to run. I can run this by connecting 3 220V wires to it, just like you'd use 3 4V batteries to run something that needs 12V. Suppose each wire can hold a maximum of 10A, and that's what's going through the 3 incoming wires. Now, there is a trick I can use to only need a single return wire (as opposed to the 3 incoming wires), even though it seems it would have to carry 30A (which is more than it can hold). What is the trick?"
My only thought was that one could use a transformer to take (incoming) 660V in 3 wires into 1 wire of 220V. But then would I have 3 turns on one end and one on the other?
[tex]\Delta[/tex]V2 = N2/N1 * [tex]\Delta[/tex]V1
220V = x/3 * 660V
But then x=1 turn, and what current or voltage would it carry?
elink24 said:
1One of the reasons we use AC power instead of DC is that with AC, we can use a single wire with a maximum voltage of 220V to return 660V.
Not really - the reason for using AC is that it is easier to step up/down voltages.
No, the largest voltage difference between two 230V phases is 415v - I don't know where you get 660V from
The trick is that the return line is at 0 volts, power flows back and forth through the live phases - in an ideal case there is no current in the return line.
Think of it has 2 batteries back-to-back both powering separate 1.5V lamps, you can connect the point between the two batteries to ground
The first and second paragraph look like 2 different questions. Which question are you answering? For example, first paragraph the wire has max voltage of 220V, but in second paragraph this new wire only has max current of 10A.
Edit, nevermind, hah.
Yes, I know it's confusing. The second part was an email from my teacher where he was trying to clarify the question for a student.
I got 660V because there is three wires each carrying 220V towards the appliance. So the return line would have no current, or no voltage? I guess I don't understand how a closed circuit could have part of the circuit at 0 volts.
Can anyone else help me with this problem?
Don't you hate Lex?
in case of a 3 wire system, the difference between the wire and ground is 220V. But the three wires have a phase difference of 60 degrees each. Hence, when u calculate the rms voltage between the wires, the difference is about 440V only. Here, no wires are joined to make one wire. There are 2 systems of connecting 3-phase supplies -Star and Delta. These links might help you better than me. http://eece.ksu.edu/~starret/581/3phase.html
http://www.animations.physics.unsw.edu.au/jw/power.html
  • · Replies 87 ·
  • · Replies 41 ·
19K
  • · Replies 26 ·
