Acceleration and speed as m*s^-1
Acceleration and speed can be expressed with negative powers in their units, such as m/s^-1 for speed and m/s^-2 for acceleration, which are mathematically equivalent to m/s and m/s² respectively. The discussion clarifies that these representations are simply algebraic manipulations of units, where the negative exponent indicates division. The confusion arises from interpreting the notation, but both forms convey the same physical quantities. The conversation emphasizes the importance of understanding unit notation in physics. Overall, recognizing these unit expressions enhances comprehension of motion equations.
Xecutive
I was given this question today and I have never seen acceleration or speed with a minus power in the unit (m/s^-2). Also speed in the question has a ^-1 in the unit and I thought the unit for speed was m/s (meters per second)
A body starts from rest and is subject to a constant contant acceleration of 4ms^-2 up to a speed of 20ms^-1. It then travels 20ms^-1 for 30 seconds after witch time it is retarded to a speed of 4ms^-1, if the complete motion takes 50 seconds, Find:
A) The time taken to reach 20ms^-1.
B) The retardation.
C)Total distance travelled.
I have know idea what these strange units mean.
Hi Xecutive. Welcome to PF!
It is simply standard algebra applied to units (which should be treated as mathematical objects).
$$x^{-1} = \frac{1}{x}$$
$$\mathrm{m} \; \mathrm{s}^{-1} = \frac{\mathrm{m}}{\mathrm{s}}$$
$$\mathrm{m} \; \mathrm{s}^{-2} = \frac{\mathrm{m}}{\mathrm{s}^2}$$
Note that it is not ##\mathrm{m} / \mathrm{s}^{-1}##, but ##\mathrm{m} \; \mathrm{s}^{-1}##. The former would give
\mathrm{m} / \mathrm{s}^{-1} = \frac{\mathrm{m}}{\mathrm{s}^{-1}} = \mathrm{m} \; \mathrm{s}
you mean ms^-2 not m/s^-2
yes, the unit for speed is m/s, and m/s can be written as ms^-1...it's just taking the denominator, s, and placing it in the numerator as s^-1.
I personally would rather see it written as m/s instead of ms^-1, but they are nevertheless mathematically the same unit, just an algebraic manipulation of the variables.
Welcome to these forums!
It seems so obvious now.
Thanks.
