Finding velocity when angular acceleration depends on angle
2 replies · 10K views
Aladsair
All right, the problem is that I have a motor that's acceleration at a rate of a = 6 theta rad/s^2. For the bigger problem that this is part of, I need to find out the velocity function. How do I do this if a isn't given in terms of t?
omega = d theta/dt a = d omega / dt
All I can think of is that
a = 6 theta
integrate both sides for t
v = 6 theta t
theta = 3 theta t^2? that doesn't make sense!
and theta is really theta(t), so how can I integrate that function if I don't know what i is? :confused:
help me calculus gurus!
I Think you have to use the result [tex]a=x''=\frac{d}{dx} (\frac{1}{2}v^2)[/tex].
That result can be obtained as such - [tex]\frac{d}{dx} ((1/2) v^2) = \frac{d}{dv} ((1/2) v^2) \cdot \frac{dv}{dx}=v\frac{dv}{dx}[/tex] by the chain rule. Another application of the chain rule: [tex]v\frac{dv}{dx} = \frac{dx}{dt}\cdot\frac{dv}{dx} = \frac{dv}{dt}=a[/tex]
actually as it turned out:
a(t) = 6 theta
better put as
a(t) = 6 theta(t)
a(t) is just the second derative of theta(t), so
theta''(t) = 6 theta(t)
tossing away the 6 mentally for a second, what function equals its own second derative? e does! so let's play with that and see what we get
if theta(t) = e^t, then theta''(t) = e^t. Okay, but we need to bring that 6 back in. So, theta (t) = e^sqrt6 t, theta'(t) = v(t) = sqrt6 e^sqrt6 t, and v''(t) = a(t) = 6 e^sqrt6 t.
To check it:a(t) = 6 e^sqrt6 t. e^sqrt6 t = theta(t) substitute and we get back to the original a(t) = 6 theta.
yay :) using this I got the right answer for my problem!
But I'm on another problem (last one, promise) with similar premises.
omega(t) = 5 (theta(t))^2 is what I'm given.
So theta'(t) = 5 (theta(t))^2
Toss away the 5, we can deal with it later...but what function equals its derative when you square it? :confused:
