Acceleration due to gravity on a planet's surface
11 replies · 3K views
cary5
What is the acceleration due to gravity on the surface of a planet with mass 5.00 x 1023 kg and radius 3.00 x 107 m? If you need to, suppose that a block of mass 50 kg is at rest on the surface. Why does it not matter what the mass of the block is?
a= Fnet/mass
i don't know the Fnet
Fg=G*m*m/r sqd
but that does not give me g and besids i need 2 masses for this
cary5 said:
Fg=G*m*m/r sqd
You have the mass of the planet--that's all you need. Use the equation from your first post.
Fnet/5*1o^23=a ?
now i have 2 varabls
cary5 said:
Fnet/5*1o^23=a ?
No. Write the force of gravity on some mass m as:
Fg = G*M*m/r^2
where M is the mass of the planet
The acceleration due to gravity is Fg/m.
Fg = G*M*m/r^2
Fg=(6.67*10^-11)(5.00*10^23)(m)/(3.00*10^7)^2
=0.037m
=0.037m
Sounds good to me. So what's the acceleration due to gravity?
0.037m/5.0*10^23
=(7.4*10^-26)m
cary5 said:
0.037m/5.0*10^23
=(7.4*10^-26)m
No. Go back to post #6. a = Fg/m (not Fg/M)
cary5 said:
What is the acceleration due to gravity on the surface of a planet with mass 5.00 x 1023 kg and radius 3.00 x 107 m? If you need to, suppose that a block of mass 50 kg is at rest on the surface. Why does it not matter what the mass of the block is?a= Fnet/massi don't know the Fnet
Acceleration due to gravity is the same as the force of gravity for a 1 kg mass. For example, Earth's acceleration due to gravity is 9.8 m/s/s while its force for a one kg mass is 9.8 N. From this you can assume the second mass needed is one kg.
This allows you to use Newton's Universal Law of Gravity to isolate for Fg. If you used the second mass of the object as one, it should be the same for the acceleration due to gravity on that planet.
ya that sounds good and it actuly makes sense
