- 174
GR is not required for resolution of the twin paradox even for accelerated or non-inertial motion (GR is only required for curvature effects i.e. non-flat spacetime)arindamsinha said:That is tantamount to saying the Twin Paradox requires GR for explanation, when seen from the traveling twin's perspective. Not what I have seen anywhere else, as the resolution seems to have been within SR from both observers' perspective, inclusive of acceleration. However, very relevant to the question I asked, if this is true. Will wait to hear more.
Acceleration does in no way affect time dilation; the formula isarindamsinha said:The acceleration (assuming it is quick and sharp) is not causing much of the time dilation, velocity is. So what has the acceleration changed? Are we not going into GR territory when we attempt to answer this question?
[tex]\tau = \int_0^t dt\,\sqrt{1-\vec{v}^2/c^2}[/tex]
Here τ is the proper time a moving (possibly accelerated) clock, t is the coordinate time, i.e. the proper time of an inertial clock. As you can see only speed is relevant.
This is a very problematic example. It's similar to purely accelerated motion w/o curvature, but it's not identical. The solution for the infinite plate is not identical to the Rindler coordinates for an accelerated observer in flat spacetime.arindamsinha said:Gravity of an infinite (or say very large) flat object causes no real spacetime curvature, but does create gravitational potential. The equivalence principle will still hold. (I can expand on this with an example, if needed).
But in principle this doesn't matter b/c it's only one specific example; results based on this solution must not be generalized
I think I begin to understand you problem: accelerated motion in flat spacetime is still described by flat spacetime (i.e. a spacetime with vanishing curvature). Acceleration causes the metric to become noin-trivial, but it remains flat. A simple example a polar coordinates which are non-trivial co,mpared to cartesian coordinates, but which still describe the same flat space!arindamsinha said:... and the moment they do, spacetime is no longer flat between them and any inertial frames nearby. This may sound like heresy, but let's think about this. We can consider the accelerating rocket to be in a different gravity by the equivalence principle. This is the crux of my original question.
So accelerated observers in flat spacetime are accelerated observers in flat spacetime ;-)
arindamsinha said:So when we are talking about acceleration and gravity equivalence, the tidal nature, though important in some cases, is not relevant to my original question.
OK, you original question was
No. Acceleration of observers (clocks, ..) is part of SR already.arindamsinha said:Does putting the concept of acceleration in SR make it equivalent to GR?
Yesarindamsinha said:... seem to say that SR can handle acceleration fine, but not gravity.
No! As I said, the equivalence principle only says that one cannot distinguish gravity and acceleration locally; that does not imply that they are identical globally.arindamsinha said:However, an acceleration IS gravity by the equivalence principle, so what's the difference?
Wikipedia says "The local effects of motion in a curved space (gravitation) are indistinguishable from those of an accelerated observer in flat space, without exception"
Yes, this is truearindamsinha said:... saying that the Twin Paradox can be resolved within SR framework and does not require GR.
I don't like this explanation. The situation is best described in terms of a simple formula: Two twins A and B are traveling along two arbitrary world lines CA and CB. Start point and end point are identical, the curves are arbitrary, except for the fact that v < c must hold. That means that in principle both twins could be accelerated w.r.t. Now we introduce an inertial frame (one twin can be located in the origin of this frame, but that's not required). The result does not depend on this frame, it can be formulated frame-independent, but for practical calculations and simple explanations a frame is required.arindamsinha said:The main differentiator though is that one of the twins preferentially 'feels acceleration'.
Then the two proper times τA and τB measured by the twins A and B along their world lines CA and CB are
[tex]\tau_{A,B} = \int_0^t dt\,\sqrt{1-\vec{v}_{A,B}^2/c^2}[/tex]
If one twin himself defines the inertial frame then his v is zero and his proper time is equal to the coordinate time.
Formulated that way there is no paradox to be resolved, there's only a formula for the calculation of proper times.
