Acceleration of a spring - mass system
34 replies · 4K views · last reply
songoku
The diagram given below.
Find the acceleration of each mass when the string connecting ##m_4## to the ground is cut.
You can assume that the system is at equilibrium before the string is cut, the string is massless and inextensible, the springs are massless, the pulley is smooth and massless.
Newton 2nd law
m1 = top left
m2 = bottom left
m3 = top right
m4 = bottom right
My questions:
1. Will all the object (m1, m2, m3,and m4) have same acceleration?
2. Should I assume initial extension of both spring is the same? (only based on the picture)
3. Will the extension of the spring change after the string is cut?
Thanks
BvU said:
https://www.physicsforums.com/threads/homework-help-guidelines-for-students-and-helpers.686781/
Your attempt is appreciated (and required according to the guidelines): what do you think ?
I have tried to draw free body diagram for each object when they are in equilibrium.
For m1, there are tension upwards, weight downwards and spring force downwards
For m2, there are tension upwards and weight downwards
For m3, there are tension upwards, weight downwards and spring force downwards
For m4, there are tension downwards, weight downwards and spring force upwards
After the string is cut, I tried to set up equation of Newton 2nd law but not sure about all the things I asked in post#1
I do not know whether the acceleration of all the masses will be the same or not. Maybe the acceleration can be the same because they all move as one system but I also think the acceleration can be different if somehow the extension of the spring changes during the motion, so I can't proceed.
How to know whether the extension will change or not during the motion?
Thanks
Then assume not. If they are, the equations will lead to that.
ΣF1 = k.x1 + m1.g - T
m1.a1 = k.x1 + m1.g - T ...(1)
ΣF2 = m2.g- k.x1
m2.a2 = m2.g- k.x1 ... (2)
ΣF3 = T - k.x2 - m3.g
m3.a3 = T - k.x2 - m3.g ...(3)
ΣF4 = k.x2 - m4.g
m4.a4 = k.x2 - m4.g ... (4)
Then how to continue? Thanks
Count the number of unknowns to check if you miss an equation ...
And: what is ##T, x_1, ## etc ?
Do you describe equilibrium, or the situation after the wire is cut ?
ΣF2 = m2.g- k.x1
ΣF4 = k.x2 - m4.g
The amount the spring on the left is stretched depends on both ##x_1## and ##x_2##. Same issue with the spring on the right. Your equations don't reflect this.
I have 7 unknowns (a1, a2, a3, a4, T, x1, x2) and 4 equations so I am missing 3 equations and I do not know what those 3 equations are
T = tension on string connecting m1 and pulley = tension on string connecting m3 and pulley
x1 = extension of spring connecting m1 and m2
x2 = extension of spring connecting m3 and m4
I describe the situation after the wire connecting m4 and ground is cut.
I assume at equilibrium, both spring are extended by same amount so the springs produce equal forces on all the masses (let say k.x, where x is extension of both spring when the system is in equilibrium)
After the wire is cut, I assume the extension of both springs is not the same so on left spring is x1 and right spring is x2
haruspex said:
"string is massless and inextensible"
Sorry I don't understand the hint. What I can do about "string is massless and inextensible" is assigning same value of tension on string on left and right side of the pulley but I don't think this is what you mean
I don't even realize this, that the amount the spring on the left is stretched depends on both ##x_1## and ##x_2## :redface:
I can say I don't understand how the system will move. This is what I thought at first:
1.
m3 and m4 will move upwards and because I don't understand whether they will move with same acceleration or not, I assume they don't. The right spring will have less extension compared to when the system is equilibrium so the extension of spring changes from x to x2, where x > x2 (don't understand why, just pure guessing).
2.
m1 and m2 will move downwards and because I don't understand whether they will move with same acceleration or not, I assume they don't. The left spring will have more extension compared to when the system is equilibrium so the extension of spring changes from x to x1, where x < x1 (again, just pure guessing)
Based on vela's hint, it is obvious that my thinking is wrong. The extension of right spring does not change from x to x2 and extension of left spring does not changes from x to x1 but I don't know how to relate the extension to both x1 and x2
Thanks
If it is inextensible, what is the relationship between the acceleration of one end and the acceleration of the other end?
Oh, the acceleration should be the same so a1 = a3
What will be the next step? What should I understand to continue? Thanks
We are only concerned with the instant after the string is cut. What will be the extensions at that time?
Will be the same as initial extension of the spring when at equilibrium?
When at equilibrium, how will the extension of the spring be? I am trying to understand the direction of the restoring force. Let say I consider the spring on the right, is the extension of the spring is both upwards and downwards (I mean m4 will cause downwards extension and m3 causes upwards extension) so the restoring force on m4 will be upwards and on m3 will be downwards?
Thanks
Thanks
Extension is how much longer the spring is than when it is relaxed. There is no separate upwards and downwards. Likewise, it exerts the same pull at each end.
So the extension of the spring at the instant when the wire is cut is the same as the extension of the spring when at equilibrium? I think from vela's hint there will be change in the extension, or maybe I am misinterpreting something?
Thanks
Yes. It can't change instantly.
songoku said:
vela's hint
@vela seems to have assumed your x variables refer to the heights of masses.
You didn't define them, but I assume they are the spring extensions.
Ok, I think I am missing one more equation. Maybe equation relating a1 to a2 or a3 to a4? Will a1 be the same as a2 because at the instant the wire is cut, m1, the left spring and m2 will move downwards as one system and also the extension of the spring has not changed?
Thanks
How so?
You know the tensions in the springs now. That leaves four accelerations (but two are the same), and the tension in the string. You have four equations. Solve.
haruspex said:
How so?
At equilibrium position:
1. for object m1
∑F = 0
T = m1.g + kx (where T = tension on string connecting m1 and pulley = tension on string connecting m3 and pulley and x is extension of the sping)
2. for object m2
∑F = 0
kx = m2.g
3. for object m3
∑F = 0
T = m3.g + kx
4. for object m4
∑F = 0
kx = m4.g + Ts (where Ts is the tension on string connecting m4 to ground)After string connecting m4 to ground is cut:
1. for object m1
∑F1 = m1 . a1
k.x + m1.g - T' = m1 . a1 → I think the magnitude of T will change after Ts is cut because if not, m1 won't have acceleration so I use T' to denote the magnitude of the tension connecting m1 and pulley when m1 is accelerating. Am I correct?
2. for object m2
∑F2 = m2 . a2
m2 . g - kx = m2 . a2 → because m2 . g = kx so a2 = 0?
3. for object m3
∑F3 = m3 . a1
T' - kx - m3.g = m3 . a1
4. for object m4
∑F4 = m4 . a4
kx - m4.g = m4 . a4
Am I correct until this part?
Thanks
Yes, I did. Sorry. Carry on!
It was on me because I didn't define the variables :sorry:
Counting variables is still a problem: you need to distinguish ##x_1## and ##x_2##. The picture shows both springs have the same ##k##.
"Knowns" ##\qquad m_1, m_2, m_3, m_4, k##
Unknowns ## \qquad T, T_s, x_1, x_2##
4 equations, so now the unknowns are determined. In particular ##T_s##
songoku said:
After string connecting ##m_4## to ground is cut:
Counting variables is now a big problem: You can't make do with ##x_1## and ##x_2## any more: there are 4 masses and three accelerations, so you'll need to re-think the kx
My suggestion: have four ##x## (well defined) and four ##a## and try to find 8 equations (##a_1 = -a_3 ## being one of them)
It might also help if you first do the exercise with ## m_2 = m_4 = 0 ## :nb) .
--------[edit: added:]---------
Yes.
BvU said:
[after string is cut]
But those have not changed. The only unknowns are the tension in the string and three accelerations.
My mistake --
1. for object m1
∑F = 0
2. for object m2
∑F = 0
kx = m2.g
3. for object m3
∑F = 0
T = m3.g + kx
4. for object m4
∑F = 0
1. for object m1
∑F1 = m1 . a1
2. for object m2
∑F2 = m2 . a2
3. for object m3
∑F3 = m3 . a1
4. for object m4
∑F4 = m4 . a4
kx - m4.g = m4 . a4
Thanks
Is my working correct? Acceleration of object 2 is zero?
Thanks
Thanks
Yes, but you seem to have overlooked @BvU 's advice:
BvU said:
you need to distinguish x1 and x2.
Let me redo:
1. for object m1
∑F = 0
T = m1.g + kx1 ...(i) (where T = tension on string connecting m1 and pulley = tension on string connecting m3 and pulley and x is extension of the left sping)
2. for object m2
∑F = 0
kx1 = m2.g ... (ii)
3. for object m3
∑F = 0
T = m3.g + kx2...(iii) (where x2 is the extension of the right spring)
4. for object m4
∑F = 0
kx2 = m4.g + Ts ...(iv) (where Ts is the tension on string connecting m4 to ground)
From (i) and (ii): T = m1.g + m2.g ...(v)
From (v) and (iii):
m1.g + m2.g = m3.g + kx2
kx2 = m1.g + m2.g - m3.g ... (vi)After string connecting m4 to ground is cut:
1. for object m1
∑F1 = m1 . a1
k.x1 + m1.g - T' = m1 . a1, where T' is the tension of string after Ts is cut
m2.g + m1.g - T' = m1 . a1
T' = m2.g + m1.g - m1 . a1 ... (vii)
2. for object m2
∑F2 = m2 . a2
m2 . g - kx1 = m2 . a2
a2 = 0
3. for object m3
∑F3 = m3 . a1
T' - kx2 - m3.g = m3 . a1 ... (viii)
From (vi), (vii) and (viii):
m2.g + m1.g - m1 . a1 - m1.g - m2.g + m3.g - m3.g = m3 . a1
a1 = 0?
Thanks
songoku said:
Let me redo:
1. for object m1
∑F = 0
2. for object m2
∑F = 0
kx1 = m2.g ... (ii)
3. for object m3
∑F = 0
4. for object m4
∑F = 0
From (v) and (iii):
1. for object m1
∑F1 = m1 . a1
2. for object m2
∑F2 = m2 . a2
a2 = 0
3. for object m3
∑F3 = m3 . a1
a1 = 0?
Thanks
Right so far. What about m4's acceleration?
For object m4:
k.x2 - m4.g = m4 . a4
m1.g + m2.g - m3.g - m4.g = m4. a4
a4 = (m1.g + m2.g - m3.g - m4.g) / m4
Only object 4 is accelerating, while object 1, object 2 and object 3 move with constant speed?
Thanks
songoku said:
For object m4:
Thanks
Yes, but what "constant speed"?
