Accelerometer and Displacement
In a discussion about measuring displacement from acceleration data in a Single Degree of Freedom vibration system, it was noted that the user has acceleration data corresponding to varying excitation frequencies. The key challenge is integrating the acceleration data to find displacement without a time variable. It was suggested that to accurately derive displacement, a steady frequency measurement is necessary to collect a sequence of acceleration values over time. The equations for displacement and its derivatives were provided, emphasizing the relationship between acceleration, frequency, and time. Ultimately, proper measurement techniques and data collection methods are crucial for accurately plotting displacement against frequency.
makethings
In Single Degree of Freedom vibration with harmonic support motion, I have used an accelerometer to measure acceleration of the vibrating system. The frequency of the support motion is sweeped through in order to find the resonant natural frequency of the system. So in tabular form I have frequency data and acceleration data. How do I find displacement from this data?
I figured you have to integrate twice...but time is not a variable. so i don't know what to integrate.
What is the equation for the position of your measurement device as a function of time? It's a sinusoid with an amplitude A, correct? What do you get when you differentiate that x(t) equation once? What comes out of the sin() function when you do that first differentiation? And then when you take the derivative of that v(t) equation, what comes out of the sin() term again? Now do you have enough info to solve the problem?
but there are no time values... my data makes it look like acceleration is a function of excitation frequency
Acceleration is a function of frequency, given the same amplitude. Write out the equations and you will see that.
You can use the acceleration data to find maximum displacement quite easily with no math, if that's all youre looking for
If x: displacement of the mass, w: excitation frequency of the support motion, A: amplitude, t: time
response is (ignoring phase):
x = A sin (wt)
x' = A w cos (wt)
x" = -A w^2 sin (wt)
If I were to differentiate wrt to frequency
x' = A t cos (wt)
x" = -A t^2 sin (wt)
I have the value of x", and w...but again... how do I take care of that time variable..
Freq (Hz) Acceleration(g)
15.01472 0.3581786
15.02945 0.3570644
15.0442 0.3566944
15.05897 0.3563249
15.07374 0.3559486
15.08854 0.3558424
15.10334 0.3557363
That's some of the data I have.. and I want to be able to plot a displacement vs freq. graph.
Do you know how you measured the acceleration values?
Clearly acceleration is a function of both excitation frequency and time. Obviously, at each frequency, you took some measurement of the acceleration of the object, but how did you make the measurements? If you just took one measurement at each frequency value, how do you expect to find displacement? You need to hold the frequency steady (instead of sweeping it) for some time, record a sequence of sampled acceleration values, and then you can integrate, then you move on to the next point in frequency.
  • · Replies 17 ·
13K
