Accumulated drag coefficient over an automotive
The discussion centers on the concept of negative local drag in the context of a CFD simulation of airflow over an automobile. It explains that regions of negative slope in the accumulated drag curve indicate local areas where the drag can be negative, particularly due to faster flow creating below-ambient pressure, such as at the top of the windshield. This phenomenon does not imply that an object can have overall negative drag, but rather that specific sections can contribute negatively to the total drag. The urgency of the inquiry is noted, along with a reminder about forum rules against cross-posting. Understanding these dynamics is crucial for analyzing aerodynamic performance in automotive design.
ryan298
Hello everyone,
I have a question regarding the accumulated drag curve shown in the figure below for the CFD simulation of external flow over an automobile. (It is written Vehicle Cd in the figure)
It can be seen in several regions that the accumulated drag curve is dropping (ie., having a negative slope, for instance, as in the region between 2500 and 3500 for the x axis). Now this should mean that in those regions, the drag is negative locally, as only this would bring a reduction in the overall drag. But how is this possible,? How can drag be negative locally in the said region for instance?
Correct me if I'm misinterpreting the curve. :)
PS: 1) The figure I've posted here is taken from a source which I've referenced below
"Levin, Ridgal, Aerodynamic analysis of drag reduction devices on the underbody for SAAB 9-3 by using CFD, Master's thesis, Chalmers University of technology, 2011"
2) It is kind of urgent, so if someone could help me out ASAP, it would be great :)
No figure attached.
I am sorry. I acutally posted the same question in the automotive engineering forum as well, and the website says that since I attached the figure there, I cannot attach it again here. (not sure why)
Here is the link to the thread in the automotive forum, and the figure can be seen here
https://www.physicsforums.com/showthread.php?t=759991
Drag can definitely be negative locally - in that particular instance, I would expect the flow to be faster than freestream in the region near the top of the windshield, which means that area is below ambient pressure (negative gauge pressure). Since the top of the windshield faces forwards, a below-ambient pressure at the top of the windshield results in a negative contribution to overall drag.
(That doesn't mean that an object can have negative drag overall, just that small regions of an object can have negative drag if considered separately from the rest of the object).
Please don't post the same thread to different forums. It's against the Rules of PF and can earn you infraction points (or worse in extreme cases).
Thank you cjl, i think i get understand it now.
Steamking, I am sorry for posting it in two forums. I wasn't sure which one would be a more appropriate place to ask this question.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
