Accuracy of a flow measuring instrument
The accuracy of the flow measuring instrument is specified as 2% of Full Scale Deflection (FSD), which for a scale of 0 to 1000 Litres per hour translates to a potential absolute error of 20 Litres at a flow rate of 500 Litres per hour. This results in a nominal measurement accuracy of 500±20 LPH, leading to a relative error of 4% at this typical flow rate. Calibration against a gold standard can help quantify and correct for measurement errors, but the acceptability of the error is subjective and depends on the specific application requirements.
  • Understanding of flow measurement principles
  • Familiarity with Full Scale Deflection (FSD) terminology
  • Knowledge of calibration techniques for measuring instruments
  • Basic grasp of error analysis in measurement
  • Research calibration methods for flow measuring instruments
  • Learn about error analysis techniques in measurement systems
  • Explore standards for acceptable accuracy in flow measurement
  • Investigate the implications of relative error in practical applications
Engineers, technicians, and quality control professionals involved in flow measurement and calibration processes will benefit from this discussion.
rollingstein
I have an instrument whose spec. sheet mentions Accuracy as 2% of FSD.
The scale runs from 0 to 1000 Litres per hour. Does this mean if I check the instrument versus a gold standard calibrating instrument at a flow of 500 Litres per hour (which is our typical flow) the absolute error can be as large as 2% of 1000? i.e. 20 Litres?
If so, then the allowable error at 500 LPH nominal flow becomes 4%.
Am I doing this right?
Yes, your measurement accuracy is 500±20 LPH. There is usually also a relative error of ε%, so you measure (1+0.01ε)500±20
If you have calibration equipment you can measure the error (with a certain accuracy) and correct for it (with a certain accuracy).
If the error is allowable or not is up to you, I have no idea where the 4% comes from.
9K
