Accuracy of Current and Voltage Measurements
The discussion centers on the accuracy of current versus voltage measurements, concluding that voltage measurements are generally more accurate. This is attributed to the invasive nature of current measurement, which often requires inserting a known resistance into the circuit, potentially altering the current flow. The conversation also touches on the comparison between ammeters and multimeters, questioning whether DC current measurements are inherently more accurate than AC due to their non-alternating nature. A practical experiment involving dual digital voltmeters (DVMs) is suggested to explore the resistance introduced during current measurements.
  • Understanding of voltage and current concepts in electrical circuits
  • Familiarity with measurement tools such as ammeters and multimeters
  • Knowledge of digital voltmeters (DVMs) and their operation
  • Basic principles of resistance and its impact on circuit measurements
  • Research the accuracy differences between ammeters and multimeters in current measurement
  • Explore non-invasive current measurement techniques, such as current clamps
  • Investigate the effects of series resistance on measurement accuracy in AC versus DC circuits
  • Conduct experiments comparing the resistance introduced by DVMs during current measurements
Electrical engineers, lab technicians, and students studying electrical measurement techniques will benefit from this discussion, particularly those interested in improving measurement accuracy in circuits.
mantillab
In general, are the measurements of current or voltage more accurate?
From our lab experiments, it seems that voltage is more accurate. I'm curious as to why this is the case.
My guess is that because current itself is the measurement of the flow of the electric charges it would be more likely to fluctuate due to external forces or changes in the environment than the voltage (the difference of the electric potential between two points of a circuit) would?
In general, all you can measure is voltage. To measure current, we generally convert it to a voltage by running it through a known resistance. This is an invasive measurement, because you need to add series resistance to the circuit to measure the current. This often can change the current, so you will generally use as small a resistance as possible for the measurement. But this makes the measurement less accurate, so in making a current measurement, there is often a tradeoff between the invasiveness of the measurement, and its accuracy.
Does that make sense? Can you think of ways that you could measure the current in a less invasive way? Do you think you can make less invasive measurements better on AC or DC currents?
Thanks! I appreciate the response. Is an ammeter more accurate than a multimeter, or are they the same? Would measurement of DC currents be more accurate because they do not alternate like AC currents do?
By ammeter, I think you're referring to a moving coil galvanometer, correct?
http://en.wikipedia.org/wiki/Galvanometer
I honestly don't know how accurate they are, in comparison to inserting a series resistance and measuring the votage drop. Sounds like an interesting question that you could spend a little time reading about on the web -- a refined google search will probably get you some good websites to check out.
BTW, here's a good experiment to try the next time you're in the lab. Use 2 DVMs, and use one to measure the series resistance that the other DVM inserts in-circuit for various current measurement ranges. How much resistance is inserted for mA range current measurements? How much is inserted for A range current measurements?
