Moles of NaOH to Create Buffer Solution pH=6 in 0.42M Ethanoic Acid
  • Context: Chemistry
  • Thread starter Thread starter stunner5000pt
    Dilution
The discussion focuses on calculating the moles of NaOH required to create a buffer solution with a pH of 6 using a 0.42 M ethanoic acid solution. The calculation begins with determining the moles of ethanoic acid in 100 mL, resulting in 0.042 mol. Using the Henderson-Hasselbalch equation, the required concentration of the base is found to be 3.32 M, leading to the conclusion that 0.332 mol of NaOH must be added. The discussion emphasizes the importance of understanding the role of the conjugate base in buffer solutions.
  • Understanding of the Henderson-Hasselbalch equation
  • Knowledge of buffer solution chemistry
  • Familiarity with molarity calculations
  • Basic concepts of acid-base reactions
  • Study the Henderson-Hasselbalch equation in detail
  • Learn about buffer capacity and its significance
  • Explore the properties of conjugate acid-base pairs
  • Investigate the effects of dilution on buffer solutions
Chemistry students, laboratory technicians, and anyone involved in preparing buffer solutions for experiments or industrial applications.
stunner5000pt
You need to make an acetate buffer with a bottle of 0.42 M of ethanoic acid and a bottle of 0.15 M of NaOH. The pKa of ethanoic acid is 4.76
a. how many moles of ethanoic acid are there in 100 mL of the 0.42 M solution
b. how many moles of NaOH must be added to the 100 mL 0.42 M ethanoic acid solution to create a buffer solution of ph = 6
c. what volume of NaOH should be added in mL to reach this pH
Henderson Hasselbach equation
the first and second seem easy...
n = CV = (0.42 M)(0.1 L) = 0.042 mol
this is where the Henderson Hasselbach comes in
pH = pK_{a} +\log \frac{[base]}{[acid]}
6 = 4.76 + \log \frac{[base]}{0.42}
1.24 = \log \frac{[base]}{0.42}
10^{1.24} \times 0.42 = [base]
[base] = 3.32 M
n(moles of NaOH) = 3.32M x 0.1 = 0.332 mol
i know that I cannot use C1V2 = C2V2 because the amount of solution that we add would dilute the final concentration
How does one keep the concentration the same as the target 3.32 in question (b)?
Your guidance & help is always appreciated!
Thank you
Nope. NaOH is not the [base] in the HH equation.
What happens when you add NaOH to the solution of the acetic acid?
ahh... so the [base] is composed of ethanoate ions & NaOH?
But how do we separate these two from the calculation?
Nope again.
Can you have both acetic acid and NaOH in the solution?
Looks like you are missing an important part of the buffer definition - it is an acid and its _conjugate_ base.
  • · Replies 23 ·
  • · Replies 22 ·
