Acid-Base Titrations - Soda Lime and Hydrochloric Acid
  • Thread starter Thread starter ajassat
    Acid
7 replies · 12K views
ajassat
"Soda lime is 85.0% NaOH and 15.0% CaO. What volume of 0.500M Hydrochloric Acid is required to completely neutralise 2.50g of the Soda Lime?"
Hint: Consider the reactions separately
Formation of Soda Lime:
CO2 + H2O >> H2CO3
H2CO3 + 2NaOH >> Na2CO3 + heat
Na2CO3 + Ca(OH)2 >> CaCO3 + 2NaOH
number of moles = mass / relative formula mass
volume = number of moles divided by concentration
1)Find the number of moles of Soda Lime (from the equations describing its formation)
2)Deduce the number of moles of HCL from the equation describing the titration
3)Work out volume of HCL using number of moles/0.500
4. Main problems encountered
*I don't know the chemical formula for soda lime/I cannot deduce its relative formula mass
*Because of the above I cannot write a balanced equation for the titration
Guidance is greatly appreciated.
Regards,
Adam
Forget about soda lime and its production, it doesn't matter. You have 2.5 g of a mixture of NaOH and CaO. How much NaOH in the mixture? How much acid required for titration of NaOH? What about CaO?
chemical calculators - buffer calculator, concentration calculator
www.titrations.info - all about titration methods
Since there 85% of NaOH, the mass of NaOH in the 2.5g mixture is:
(85/100)*2.5 = 2.12500
Therefore the mass of CaO in the mixture is:
2.5 - 2.12500 = 0.375g
The titration of NaOH:
NaOH + HCL >> NaCl + H20
number of moles of NaOH = m/Mr = 2.12500/40 = 0.053125 mol
From equation number of moles of HCL = 0.053125 mol
Therefore volume(HCL) = n/c = (0.053125/0.500)*1000 = 106.25 cm3
Is this first value for volume correct?
Continuing with the titration of CaO
CaO + 2HCL >> CaCl2 + H2O
number of moles = m/mr = 0.375/56 = 0.00669642857
From equation, number of moles (HCL) = 2*0.00669642857 = 0.013938571
Therefore:
V = n/c = (0.0134/0.500)*1000 = 26.8cm3
Adding the two calculated volumes gives
total volume of HCL required = 26.8 + 106.25 = 133.05cm3 or 133cm3 (to 3 sig fig0
Borek: Please confirm :)
Approach is correct, but you have eaten one digit, so the final result is off.
It should be: 0.0133928571
Which when rounded to 3 sig fig is 0.0134
NB: See adjusted Calculation and answer
