Adding Arrays Together with Pointers in C
  • Thread starter Thread starter AK2
    Arrays Pointers
AK2
Code:
#include <stdio.h>
#define K 10
int array1[K], array2[K];
int *ptr;
int addarrays(int x[],int y[]);
main()
      int count;
      for (count = 0;count < K; count++)
           puts("Enter numbers into array1");
           scanf("%d", array1[count]);
           puts("Enter numbers into array2");
           scanf("%d", array2[count]);
       [B]ptr = addarrays(array1,array2);[/B]
           printf("%d + %d = %d\n",array1[count], array2[count], *(ptr+count));
       return 0;
int addarrays(int x[], int y[])
       int count, total[K];
       for(count = 0; count< K; count++)
           total[count] = array1[countk] = array2[count];
       return total;
i compiled this code in dev c++ ide and i got an error on the bolded line. The purpose of the code is two add two arrays and put the results in a new array and print the three arrays. The function addarrays is meant to return a pointer to the first array element to the calling program. This is where the error lies.
Three problems here:
  1. You declared addarrays as a function that returns an int but you are assigning the result to a variable declared as an int*. This is the cause of the immediate problem.
    [*]addarrays returns an int*, contrary to the declared return value (an int). You probably got a compile error on the return statement from addarrays as well.
    [*]You are returning a pointer to a function-scope automatic variable in addarrays.
You can fix the first two problems by declaring and defining addarrays as a function that returns an int*. This will not fix the third problem. That return statement in addarrays is completely invalid -- and most compilers will not catch it. You are invoking undefined behavior here! Never return a pointer to a function-scope automatic variable. One way to fix this problem is to make total a static variable. This will create other problems (it makes your function non-reentrant), but these are probably beyond the scope of the class you are taking.
Thanks for the help. I am still a beginner. C is the first computer language i am learning. I am using Sams Teach Yourself C. I am currently on the 9th chapter(Understanding Pointers) of the 21 chapter book. I have not yet covered the terms static variable and function-scope automatic variable. I will probably come back to the question when I have reached those terms in the book. The question I posted is a do it on your own question in the book I am using to learn C. I did what you asked me to do in the first two points and as you said earlier it didnt solve the last problem.
Aside from the problems that DH points out, your addarrays function is either misnamed or has a semantic error in it. A casual peruser of your code would expect addarrays to add two arrays together, and return an array (actually an array address, which is essentially the same as an int * value). That's not what it does -- you probably meant for the 2nd assignment in the bolded line below to be +.
Note that fixing this alone doesn't solve your problems.
Code:
       [B]total[count] = array1[countk] = array2[count];[/B]
   return total;
