Adding noise and solving stochastic ODEs in Python
The discussion revolves around the modeling of a coupled system of ordinary differential equations (ODEs) that simulate the behavior of ITMblood in response to various factors, including the introduction of noise. Participants explore methods for solving these equations in Python, particularly focusing on the challenges of incorporating stochastic elements into the model.
  • One participant describes a coupled ODE model where ITMblood is manipulated to observe system behavior, particularly its collapse at high concentrations.
  • Another participant proposes a simplified two-equation model to facilitate analysis, noting that ITMblood will decay without a source function and exhibits asymptotic behavior.
  • There is a discussion about the introduction of a source term and the confusion regarding the term "sinusoidal," which was clarified to mean "sigmoidal." The source term is intended to mimic real-world fluctuations in ITM concentrations.
  • Participants express uncertainty about the effects of the noise term and its role in the model, with one participant seeking clarification on its purpose.
  • One participant suggests that if the SDE solver continues to produce errors, generating white noise from a normal distribution could be a viable alternative to add noise to the derivatives function.
  • Another participant shares their experience with the ODE solver, indicating that it sometimes produces errors even with no noise, raising questions about the model's complexity and initial conditions.
Participants generally agree on the complexity of the model and the challenges associated with solving it, but there is no consensus on the best approach to introduce noise or resolve the errors encountered with the solvers. Multiple competing views on how to handle the noise and the model's structure remain present.
Participants note the potential limitations of the model, including the complexity of the system and the dependence on initial conditions, which may contribute to the errors experienced with the solvers. There are unresolved questions regarding the effectiveness of the proposed methods for introducing noise.
vabsie
TL;DR
I have 14 coupled ordinary differential equations. I am trying to increase the concentration of one of the ODEs by adding a sinusoidal equation that is at the same time "noisy". This noise I introduce follows a gaussian distribution with mean 0 and sigma that I vary in several experiments. I have not tried calculating for an analytical solution (not sure if even possible) but only used Python to solve the system. I don't know if I am doing it right. Any help is appreciated.
The Coupled ODE Model
Below are my coupled differential equations, where the only variable I try to meddle with is the ITMblood. The motivation here is if I try to increase ITMblood (in the next section I will show how I do it), at some concentration of ITMblood (most likely a very huge one) , the system below "collapses." That is, some of the concentrations just flattens out.
Introducing Noise to ITMblood
This is just a naive method that I am doing. So I just add a "source" of this ITMblood that follows a sinusoidal function which plateaus at rITMaddpeak and somehow starts "late" controlled by tITMadd. Then I add "noise" that simply follows a gaussian distribution with mu = 0 and sigma that I vary as part of my experiments.
Python Library Used to Solve the Equations
scipy.integrate.odeint
note: I have tried an existing library (sdeint) specifically designed for SDEs but for some reason, the solver just can't handle the system/blows up, even when I have not added noise yet (used this as sanity check).
Am I doing this right? Does this method of introducing noise make sense? Thank you very much! I can upload my notebooks if necessary.
Technology news on Phys.org
Holy equation, batman! That's a lot of equations to process :oldbiggrin:
If you don't mind, I'm going to arbitrarily cut out some of your variables and make a toy model that will be easier for myself and other folks to analyze. If I end up cutting out something that's extremely relevant, please speak up.
How about a two-equation model: $$\frac{dITM_{blood}}{dt} = -\mu_{ITM} dITM_{blood} - \lambda_{ITM | AP_E} AP_{Eblood} ITM_{blood} + \frac{r_{ITMpeak}}{1+\exp[r_{ITM}(t-t_{ITM})]}\left(1 - \frac{ITM_{blood}}{ITM_{max}} \right)$$ $$\frac{dAP_{Eblood}}{dt} = -\mu_{AP_E} AP_{Eblood} - \lambda_{ITM|AP_E} ITM_{blood} AP_{Eblood}$$
What I see here is that ##ITM_{blood}## will decay if there is no source function, and that ##ITM_{blood}## has some funky time-dependent behavior that asymptotic flattens out as ##ITM_{blood} \rightarrow ITM_{max}## and also flattens out asymptotically as ##r_{ITM}t \rightarrow \infty##. If you want to observe this behavior, it seems all you need is a constant source term:
$$\frac{dITM_{blood}}{dt} = -\mu_{ITM} dITM_{blood} - \lambda_{ITM | AP_E} AP_{Eblood} ITM_{blood} + \frac{r_{ITMpeak}}{1+\exp[r_{ITM}(t-t_{ITM})]}\left(1 - \frac{ITM_{blood}}{ITM_{max}} \right) + S$$ where ##S = \mu_{ITM} ITM_{max} ##. That constant source term will cause ##ITM_{blood}## to reach equilibrium at ##ITM_{max}## where you will see flattening of the funky time-dependence. I'm not sure what you hope to accomplish with the inverse exponential source you added (also, why did you call that a sinusoidal term? that part was very confusing to me and I think it's just a matter of context). It's also not clear to me what the noise term would do for you. Can you elaborate?
Go ahead! I did not want to miss out on the details, which could be important. That huge system is actually a model of the immune system. :oldbiggrin: But you're right! Trimming it down to a toy model won't hurt.
Twigg said:
What I see here is that ITMblood will decay if there is no source function
You are absolutely right! To make it comprehensible, ITM here means Inflammation Triggering Moieties or the bad things that make your immune system fire up.
Twigg said:
ITMblood has some funky time-dependent behavior that asymptotic flattens out as ITMblood→ITMmax and also flattens out asymptotically as
Yes! The sigmoidal function has an initial peak controlled by ##r_{ITMpeak}##. If the concentration of ##ITM_{blood}## closes into ##ITM_{max}##, it just stops adding up. So the following term controls the slow build up of ITMs. :woot:
$$1-\frac{ITM_{blood}}{ITM_{max}}$$
It basically means the system can only handle this much maximum concentration of ITMs.
I wanted to add a source of ITMs (as this original equation/profile for ##ITM_{blood}## eventually decays). Let's just say, some medical complications happen and suddenly we have another source of those bad things (ITMs). BUT the catch is, I wanted to make it noisy to mimic a real system (as opposed to a deterministic one).
My bad! This was a typo. Let me edit it in my original post. I was referring to "sigmoidal" :nb).This is how I want to add the source term of ITMs so it won't increase linearly, and instead stop increasing at a maximum value. I hope that's clear?
So why I am adding noise? To mimic a real system! And hopefully, if the concentration of ITMs becomes critical to the system, I will see a "collapse" (I imagine this as some concentrations not going back to normal values). The noise I can "study" using early warning signals for critical transitions.
Thank you very much! I still don't know how to add the noise. My solver is sometimes throwing off errors. :frown:o_O And it is not helping because I want to do as many experiments as possible (ie varying the noise that I add).
PS
Bummer, I can't edit the original post anymore. Sinusoidal was supposed to be sigmoidal. Sorry for the confusion!
I think I see what you mean now. Sorry if I was just saying things that were obvious! Just wanted to make sure I was reading things correctly.
Unfortunately, we would need more information to tell you why your solver (I take it this is the SDE solver?) is throwing errors, and given the size of your model we probably wouldn't be able to find the issue in our spare time. All I can really offer you on this front is I encourage you to follow best coding practices, and make sure to thoroughly unit test your function that spits out the time derivatives. If you can reproduce the SDE errors with a toy model, then we might be able to help!
If the SDE solver continues to be a problem, you could always fall back on the ODE solver and generate white noise from a normal distribution to add into your derivatives function. If you do this process many times and do good statistical inference, you should be able to learn just as much, at the expense of computational resources / time. This might actually be the less treacherous approach if you expect some kind of phase transition / bifurcation / etc.
Thank you very much! This is the approach that I am doing at the moment. I am not using the SDE solver as even with a vanilla implementation (setting noise to 0, for sanity check), it is still spewing out errors, probably because of the complexity/size of my system. I even tried doing the manual approach (Euler-Maruyama), meaning I did not use a solver but coded from scratch. But it took forever to run. Yikes.
So I am using my ODE solver for this. Sometimes, it gives me ok results, sometimes, it just gives me errors. :eek:
I guess I just have to catch the best ones!
Thank you very much for your time!
Does the ODE solver still spit out errors when you set the noise to 0? And does it consistently spit out errors or does it only do it for certain initial conditions? If it happens randomly with no noise and identical initial conditions, something is very wack with the derivatives function.
yeaaah I would definitely stick to scipy
The ODE solver is SUPER A-OK when noise is 0. The problem happens when I add noise :H Sometimes, it gives out errors, sometimes it's ok.
Especially in one of my experiments where I add ITMs for a period of 3 hours ONLY (for example). So you'd imagine that after this period of 3 hours, ITMs just decay. ODE solver is ok with no noise. But the moment I add noise, everything just goes crazy no matter how many times I vary the random seed!
BUT when I add ITMS continuously (no restricted time period) with noise, I SOMETIMES get ok results. o_O
Can you show a plot? There's a lot of different kinds of crazy
Scenario 1
Here's what it looks like if I add a continuous source of ITMs without noise.
and with noise:
So far so good.
Scenario 2
When I add a source of ITMs for a period of say 3 hours, here's what it looks like without noise. Makes sense as the concentration of ITMs go down immediately after 3 hours.
But when I add noise, I get this weird plot that does not even make sense o_O. Most times I just get random plots that break at certain points.
Sorry for brief reply. Life caught up with me.
Smells like overflow error. The y-axis on the second plot around 4E307, and the maximum allowed value of a double float is 1.7E308. Either there's a true arithmetic overflow error or your system of equations isn't stable under a white noise source (what you used).
A few things worth trying:
(1) reduce variance of the noise source by powers of 10 until the issue stops and see if that result makes sense,
(2) try pink noise instead of white noise (take fft of white noise, apply a 1/sqrt(f) filter, then ifft; alternatively I have some code you can use let me know if you want it). If this works, it means your system of equations doesn't like high frequencies or has some poles in its transfer function. You could even apply a boxcar/cutoff filter to your noise signal to narrow down the range of problematic frequencies.
(3) try starting with the 2 equation toy model and seeing if it has the same issue. If it doesn't, add equations back into the system until it does. That will tell you which degree of freedom is problematic
Really good recommendations! I'll try these and post some updates.
Thank you very much for giving time into this. It's been a very fruitful discussion. You have no idea how stuck I was. Even created an account on here to post this. hehe :oldbiggrin:
I don't have much to contribute here, but wanted to point out that the scipy implementation of an ode solver is almost certainly running compiled C code under the hood, and not actually using python for any real work. If you want to seriously try to do this yourself, you would probably need to write it in C or C++ also.
  • · Replies 0 ·
