Adequate proof? Spivak's Calculus ; Dense sets
4 replies · 2K views
Derek Hart
Let A be a dense set**. Prove that if f is continuous and f(x) = 0 for all x in A, then f(x) = 0 for all x.
**A dense set is defined, in the book, as a set which contains a point in every open interval, such as the set of all irrational or all rational numbers.
N/A
I looked in the answer book, and spivak's proof is much different than mine. I want to know whether mine is adequate.
I began by considering a point (α, f(α)) such that f(α)<0. I then stated that there would have to be some σ so that f(x)<0 for all x such that α-σ < x <α+σ. This, however, contradicts the initial statement that A is a dense set (since f<0 for all x in (α-σ, α+σ)).
I had an almost identical argument for f>0, which i wish not to type. So does this prove that f(x)=0 for all x?
N/A
You didn't state it carefully, but what you are showing is that if f is continuous at ##\alpha## and ##f(\alpha) < 0## then you get a contradiction to A being dense. That is an indirect argument which is a reasonable way to prove it.
Alright, so to correct it I should just explicitly state that f is continuous at α?
You could write: Suppose ##f## is continuous at ##\alpha## and ##f(\alpha)< 0##. Then blahdy blah blah...which is a contradiction to ##A## being dense. Therefore ##f(x)## is identically zero. But instead of assuming ##f(\alpha) < 0## I would start with ##f(\alpha) \ne 0## and use absolute value signs in your argument so you don't have to do two cases.
