Adjoint and inverse of product of operators
The discussion confirms that the relations for adjoints and inverses of products of operators, specifically (H1 H2)* = H2* H1* and (H1 H2)^{-1} = H2^{-1} H1^{-1}, extend to bounded linear operators between infinite-dimensional Banach spaces. The definition of the adjoint operator in this context is similar to that in Hilbert spaces, though it operates between dual spaces. The proofs for these properties in infinite dimensions mirror those in finite dimensions, with considerations for the domains of unbounded operators. Participants suggest that a course in functional analysis would provide further insights into these concepts. Overall, the principles hold true across different dimensions, provided the operators are bounded.
ellilu11
I know for two linear operators $$H_1, H_2$$ between finite dimensional spaces (matrices) we have the relations (assuming their adjoints/inverses exist):
$$(H_1 H_2)^* = H_2^* H_1^*$$ and $$(H_1 H_2)^{-1} = H_2^{-1} H_1^{-1}$$
but does this extend to operators in infinite dimensions? Thanks.
Well, given a dimension N, the relations are true. Since we do not impose any restriction on N...
Yes, this is true for bounded linear operators between Banach spaces.
Okay thanks. Do you have a reference where I can learn about the Banach space case?
A course in functional analysis should help you. Do you have that in your school's schedule?
Is there a definition of the adjoint of a bounded linear operator on a Banach space? The definition I'm familiar with is for Hilbert spaces.
In the finite-dimensional case, the proofs go like this:
\begin{align}
&\langle (AB)^*x,y\rangle =\langle x,ABy\rangle =\langle A^*x,By\rangle =\langle B^*A^*x,y\rangle\\
&B^{-1}A^{-1}A B= B^{-1} I B =B^{-1} B=I.
\end{align} The proofs for bounded linear operators on an infinite-dimensional Hilbert space are the same. For unbounded linear operators, the domains of the operators are an issue. The domains are proper linear subspaces of the Hilbert space, so the first calculation can at best make sense for all ##x,y## in some proper linear subspace (I don't have time to think about the details right now), and the second calculation should be changed to
$$B^{-1}A^{-1}A Bx= B^{-1}I|_{\operatorname{dom} A}Bx =B^{-1}Bx=x,$$ for all x such that x is in the domain of B and Bx is in the domain of A.
Yes, although not everybody calls it the adjoint. If you have a operator ##T:B_1\rightarrow B_2##, then you can define ##T^*:B_2^*\rightarrow B_1^*## by ##T^*(f) = f\circ T##. Only in Hilbert spaces does this give rise to an operator ##B_2\rightarrow B_1## by the Riesz isomorphisms.
notice from micromass' definition the formula (ToS)* = S*oT* is immediate. i.e. since by definition,
we have T*(f) = foT, applying S* to both sides gives S*oT* (f) = foToS = (ToS)*(f).
so it has nothing to do with the dimension being finite. and i think you can finesse fredrick's subtle remarks in case the maps are not defined everywhere, by saying, "and hence this holds wherever both sides make sense".
If you adapt the pretty standard in functional analysis notation ##\langle x, f\rangle## for ##f(x)##, where ##x## is in a Banach space ##X## and ##f## is in its dual (i.e. a bounded linear functional on ##X##) then the formula defining the adjoin (dual) operator is absolutely the same as for the Hilbert spaces. Only now, as micromass mentioned the dual operator acts between dual spaces. And the proof Frederik presented for ##(AB)^*=B^*A^*## for Hilbert spaces works in the case of Banach spaces without any changes.
