Advantage and disadvantage of resonance
  • Thread starter kindaichi
  • Tags
    Resonance
In summary, resonance can have both advantages and disadvantages depending on the application. In the case of a radio antenna, it is beneficial as it allows for easy coupling of energy into the system. However, in the case of a bridge, resonances can be detrimental and can even cause collapse. Multiple resonances can also lead to unpredictability in systems. Despite this, resonance can also provide entertainment, as shown in the videos provided.
kindaichi
I have always been wondering,what is the advantage and disadvantage of resonance.I am currently studying it right now,and i do know it had caused a bridge to collapse before.
It depends on the application. In a radio antenna it's a good thing, in a bridge it typically is not.
Resonances are typically frequencies where energy is easily coupled into the system. Depending on the application, this easy coupling of energy can be good or bad.
When we want to couple energy into a system, say in the case of an antenna, resonances are desirable, whereas if we want do dampen out energy in the case of anti-vibration table, resonances are bad news. Sometimes systems can exhibit multiple resonances, which is usually a bad thing no matter what, because a system that is jumping between resonances is usually rather unpredictable. Any multimode laser is a good example of where this occurs.
Claude.
oh c'mon, Russ. it makes for great entertainment!
http://video.google.com/videoplay?docid=-3932185696812733207
http://video.google.com/videoplay?docid=8849554834285920420
http://video.google.com/videoplay?docid=7836010763965729158
how can that not be good?
resonance is always good.
What is resonance and how does it work?
Resonance is a phenomenon that occurs when an object or system is subjected to an external force that matches its natural frequency, causing it to vibrate at a larger amplitude. This is due to the transfer of energy between the external force and the object's natural frequency. Resonance can occur in various systems, including mechanical, electrical, and acoustic systems.
What are the advantages of resonance?
One of the main advantages of resonance is its ability to amplify the amplitude of vibrations, making it useful in amplifying sound, signals, or energy in different systems. It can also be used to tune instruments and various mechanical devices, ensuring they operate at their optimal frequency. Additionally, resonance can be used in medical imaging, such as MRI, to enhance the signal and generate clearer images.
What are the disadvantages of resonance?
While resonance can be beneficial in many applications, it can also have negative effects. In some cases, resonance can cause unwanted vibrations, leading to structural damage or failure. This is known as resonance catastrophe and can occur when the frequency of the external force matches the natural frequency of the system. Resonance can also cause noise pollution and interfere with the operation of sensitive equipment.
How can resonance be controlled or prevented?
To prevent unwanted resonance, engineers and scientists use various techniques such as damping, stiffening, and frequency tuning. Damping involves dissipating the energy of the vibrations to reduce their amplitude. Stiffening involves increasing the rigidity of the system to change its natural frequency. Frequency tuning involves adjusting the natural frequency of the system away from the external force's frequency.
How is resonance used in different fields of science?
Resonance has many applications in different fields of science. In physics, it is used to study the properties of materials and determine their natural frequencies. In chemistry, it is used to identify the structure and composition of molecules through spectroscopy. In electronics, it is used to amplify signals and tune circuits. In medicine, it is used in imaging techniques such as MRI and ultrasound. In music, resonance is essential for creating and amplifying sound.
  • Other Physics Topics
  • Atomic and Condensed Matter
  • High Energy, Nuclear, Particle Physics
  • Science and Math Textbooks
  • Electromagnetism
  • STEM Academic Advising
